Deadlock Detected Error
What can cause this error ?
Using Ignition 8.1.35
com.inductiveautomation.ignition.common.script.JythonExecException: Traceback (most recent call last): File "", line 237, in runAction File "", line 159, in modelApply Detail: Process 38680 waits for ShareLock on transaction 2401420; blocked by process 37632. Process 37632 waits for ShareLock on transaction 2401419; blocked by process 38680. Hint: See server log for query details. Where: while updating tuple (26678,18) in relation "Metadata" at com.inductiveautomation.ignition.gateway.db.namedquery.NamedQueryExecutor$NamedQueryInstance.execute(NamedQueryExecutor.java:407) at com.inductiveautomation.ignition.gateway.db.namedquery.NamedQueryExecutor.execute(NamedQueryExecutor.java:173) at com.inductiveautomation.ignition.gateway.db.namedquery.GatewayNamedQueryManager.execute(GatewayNamedQueryManager.java:92) at com.inductiveautomation.ignition.common.db.namedquery.SecuredNamedQueryManager.execute(SecuredNamedQueryManager.java:78) at com.inductiveautomation.ignition.gateway.script.GatewayDBUtilities.runNamedQuery(GatewayDBUtilities.java:419) at jdk.internal.reflect.GeneratedMethodAccessor202.invoke(Unknown Source) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.base/java.lang.reflect.Method.invoke(Unknown Source) java.lang.Exception: java.lang.Exception: org.postgresql.util.PSQLException: ERROR: deadlock detected Detail: Process 38680 waits for ShareLock on transaction 2401420; blocked by process 37632. Process 37632 waits for ShareLock on transaction 2401419; blocked by process 38680. Hint: See server log for query details. Where: while updating tuple (26678,18) in relation "Metadata"
at org.python.core.Py.JavaError(Py.java:545)
at org.python.core.Py.JavaError(Py.java:536)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:192)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:553)
at org.python.core.PyObject.__call__(PyObject.java:477)
at org.python.core.PyObject.__call__(PyObject.java:481)
at org.python.pycode._pyx1128.modelApply$1(:22)
at org.python.pycode._pyx1128.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.PyBaseCode.call(PyBaseCode.java:306)
at org.python.core.PyFunction.function___call__(PyFunction.java:474)
at org.python.core.PyFunction.__call__(PyFunction.java:469)
at org.python.core.PyFunction.__call__(PyFunction.java:459)
at org.python.pycode._pyx1219.runAction$1(:258)
at org.python.pycode._pyx1219.call_function()
at org.python.core.PyFunction.__call__(PyFunction.java:464)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:847)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:829)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$TrackingProjectScriptManager.runFunction(ProjectScriptLifecycle.java:868)
at com.inductiveautomation.ignition.common.script.ScriptManager$ScriptFunctionImpl.invoke(ScriptManager.java:1010)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$AutoRecompilingScriptFunction.invoke(ProjectScriptLifecycle.java:950)
at com.inductiveautomation.perspective.gateway.script.ScriptFunctionHelper.invoke(ScriptFunctionHelper.java:161)
at com.inductiveautomation.perspective.gateway.script.ScriptFunctionHelper.invoke(ScriptFunctionHelper.java:98)
at com.inductiveautomation.perspective.gateway.action.ScriptAction.runAction(ScriptAction.java:80)
at com.inductiveautomation.perspective.gateway.action.ActionDecorator.runAction(ActionDecorator.java:18)
at com.inductiveautomation.perspective.gateway.action.SecuredAction.runAction(SecuredAction.java:44)
at com.inductiveautomation.perspective.gateway.model.ActionCollection$ActionSequence$ExecuteActionsTask.lambda$call$0(ActionCollection.java:263)
at com.inductiveautomation.perspective.gateway.api.LoggingContext.mdc(LoggingContext.java:54)
at com.inductiveautomation.perspective.gateway.model.ActionCollection$ActionSequence$ExecuteActionsTask.call(ActionCollection.java:252)
at com.inductiveautomation.perspective.gateway.model.ActionCollection$ActionSequence$ExecuteActionsTask.call(ActionCollection.java:221)
at com.inductiveautomation.perspective.gateway.threading.BlockingTaskQueue$TaskWrapper.run(BlockingTaskQueue.java:154)
at com.inductiveautomation.perspective.gateway.threading.BlockingWork$BlockingWorkRunnable.run(BlockingWork.java:58)
Caused by: org.python.core.PyException: java.lang.Exception: java.lang.Exception: org.postgresql.util.PSQLException: ERROR: deadlock detected Detail: Process 38680 waits for ShareLock on transaction 2401420; blocked by process 37632. Process 37632 waits for ShareLock on transaction 2401419; blocked by process 38680. Hint: See server log for query details. Where: while updating tuple (26678,18) in relation "Metadata"
... 41 common frames omitted
Caused by: java.lang.Exception: org.postgresql.util.PSQLException: ERROR: deadlock detected Detail: Process 38680 waits for ShareLock on transaction 2401420; blocked by process 37632. Process 37632 waits for ShareLock on transaction 2401419; blocked by process 38680. Hint: See server log for query details. Where: while updating tuple (26678,18) in relation "Metadata"
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
... 38 common frames omitted
Caused by: org.postgresql.util.PSQLException: ERROR: deadlock detected Detail: Process 38680 waits for ShareLock on transaction 2401420; blocked by process 37632. Process 37632 waits for ShareLock on transaction 2401419; blocked by process 38680. Hint: See server log for query details. Where: while updating tuple (26678,18) in relation "Metadata"
at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2675)
at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:2365)
at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:355)
at org.postgresql.jdbc.PgStatement.executeInternal(PgStatement.java:490)
at org.postgresql.jdbc.PgStatement.execute(PgStatement.java:408)
at org.postgresql.jdbc.PgPreparedStatement.executeWithFlags(PgPreparedStatement.java:166)
at org.postgresql.jdbc.PgPreparedStatement.executeUpdate(PgPreparedStatement.java:134)
at org.apache.commons.dbcp2.DelegatingPreparedStatement.executeUpdate(DelegatingPreparedStatement.java:136)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper$SRPreparedStatement.executeUpdate(SRConnectionWrapper.java:981)
at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper.runPrepUpdate(SRConnectionWrapper.java:181)
at com.inductiveautomation.ignition.gateway.db.namedquery.NamedQueryExecutor$NamedQueryInstance.runPrepQuery(NamedQueryExecutor.java:507)
at com.inductiveautomation.ignition.gateway.db.namedquery.NamedQueryExecutor$NamedQueryInstance.execute(NamedQueryExecutor.java:399)
No you're not; Perspective isn't compatible with Ignition 7.9.
This deadlock is entirely in PostgreSQL, not Ignition. All Ignition is doing is reporting the error message your database sent us. Investigate inside your DB.
