Dear all, I am currently using the build b2019030402. When I opened a designer on a Windows 8.1, I noticed a strange behavior on editing an OPC Item Path: the cursor does not match the screen position. I post a video to better clarify.
OPCItemPath.zip (1.9 MB)
Let me know for further information.
Thank you.
Massimo
It's probably the same as this issue below. Are you on the latest version, and did you try deleting your cache?
I’m using the version 1.0.0-beta0 (b2019030402). As per your advice, I tried to clear the cache and the problem was solved.
Thank you so much.
