I’ve found that when setting up a dynamic query (containing strings that change depending on the user’s actions) I always have the need to see the query sent to the database. For example, if my query is:
SELECT * FROM myTable WHERE id = {Root Container.selectedId}
It is very beneficial if I’m able to see the final query that’s sent to the database with the variables evaluated. I usually end up adding a dynamic string property to the Root Container for the query so I can look at it, and then I specify the Data property’s SQL query as {Root Container.myQuery}. I was wondering if there is a way I can look at the query so I don’t have to keep performing this extra step.
Thanks!
