Hello,
As many of you know machine learning is a trending topic in many fields right now.
I have been doing some research on how can we integrate this technology into our projects.
I have discovered the deeplearning4j library, it seems very popular and well documented, so I tried to make it avaliable through a script module using the Ignition SDK.
I took the scripting-rpc-example from the SDK examples and added the deeplearning4j dependences into the project pom.xml.
The problem that I found is that when I try to run the “mvn clean package” command I get this error:
[ERROR] Failed to execute goal com.inductiveautomation.ignitionsdk:ignition-maven-plugin:1.0.12:modl (package-modl) on project scripting-rpc-build: Error copying dependency
Can anyone give a hint on how can I solve this issue?
Thank you!
Attached you can find the full command output with the debug option enabled. mvn.log (1.0 MB)
And this is the full pom.xml:
<?xml version="1.0" encoding="UTF-8"?>
<project xmlns="http://maven.apache.org/POM/4.0.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
<modelVersion>4.0.0</modelVersion>
<groupId>com.inductiveautomation.ignition.examples</groupId>
<artifactId>scripting-rpc-example</artifactId>
<version>1.8.0</version>
<packaging>pom</packaging>
<properties>
<!-- Change the nd4j.backend property to nd4j-cuda-7.5-platform or nd4j-cuda-8.0-platform to use CUDA GPUs -->
<nd4j.backend>nd4j-native-platform</nd4j.backend>
<!-- <nd4j.backend>nd4j-cuda-8.0-platform</nd4j.backend> -->
<project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
<shadedClassifier>bin</shadedClassifier>
<java.version>1.8</java.version>
<nd4j.version>0.9.1</nd4j.version>
<dl4j.version>0.9.1</dl4j.version>
<datavec.version>0.9.1</datavec.version>
<arbiter.version>0.9.1</arbiter.version>
<rl4j.version>0.9.1</rl4j.version>
<!-- For Spark examples: change the _1 to _2 to switch between Spark 1 and Spark 2 -->
<dl4j.spark.version>0.9.1_spark_1</dl4j.spark.version>
<datavec.spark.version>0.9.1_spark_1</datavec.spark.version>
<!-- Scala binary version: DL4J's Spark and UI functionality are released with both Scala 2.10 and 2.11 support -->
<scala.binary.version>2.11</scala.binary.version>
<guava.version>19.0</guava.version>
<logback.version>1.1.7</logback.version>
<jfreechart.version>1.0.13</jfreechart.version>
<jcommon.version>1.0.23</jcommon.version>
<maven-compiler-plugin.version>3.6.1</maven-compiler-plugin.version>
<maven-shade-plugin.version>2.4.3</maven-shade-plugin.version>
<exec-maven-plugin.version>1.4.0</exec-maven-plugin.version>
<maven.minimum.version>3.3.1</maven.minimum.version>
<aws.sdk.version>1.11.109</aws.sdk.version>
<jackson.version>2.6.6</jackson.version>
<scala.plugin.version>3.2.2</scala.plugin.version>
</properties>
<modules>
<module>scripting-rpc-build</module>
<module>scripting-rpc-client</module>
<module>scripting-rpc-common</module>
<module>scripting-rpc-designer</module>
<module>scripting-rpc-gateway</module>
</modules>
<distributionManagement>
<snapshotRepository>
<id>sonatype-nexus-snapshots</id>
<name>Sonatype Nexus snapshot repository</name>
<url>https://oss.sonatype.org/content/repositories/snapshots</url>
</snapshotRepository>
<repository>
<id>nexus-releases</id>
<name>Nexus Release Repository</name>
<url>http://oss.sonatype.org/service/local/staging/deploy/maven2/</url>
</repository>
</distributionManagement>
<pluginRepositories>
<pluginRepository>
<id>releases</id>
<url>http://nexus.inductiveautomation.com:8081/nexus/content/repositories/inductiveautomation-releases</url>
</pluginRepository>
</pluginRepositories>
<repositories>
<repository>
<id>releases</id>
</repository>
<repository>
<id>snapshots</id>
<url>http://nexus.inductiveautomation.com:8081/nexus/content/repositories/inductiveautomation-snapshots</url>
<snapshots>
<enabled>true</enabled>
<updatePolicy>always</updatePolicy>
</snapshots>
</repository>
<repository>
<id>thirdparty</id>
<url>http://nexus.inductiveautomation.com:8081/nexus/content/repositories/inductiveautomation-thirdparty
</url>
</repository>
<repository>
<id>snapshots-repo</id>
<releases>
<enabled>false</enabled>
</releases>
<snapshots>
</snapshots>
</repository>
</repositories>
<dependencyManagement>
<dependencies>
<dependency>
<groupId>org.nd4j</groupId>
<artifactId>nd4j-native-platform</artifactId>
<version>${nd4j.version}</version>
</dependency>
<dependency>
<artifactId>nd4j-cuda-7.5-platform</artifactId>
</dependency>
<dependency>
<artifactId>nd4j-cuda-8.0-platform</artifactId>
</dependency>
</dependencies>
</dependencyManagement>
<dependencies>
<!-- ND4J backend. You need one in every DL4J project. Normally define artifactId as either "nd4j-native-platform" or "nd4j-cuda-7.5-platform" -->
<dependency>
<artifactId>${nd4j.backend}</artifactId>
</dependency>
<!-- Core DL4J functionality -->
<dependency>
<groupId>org.deeplearning4j</groupId>
<artifactId>deeplearning4j-core</artifactId>
<version>${dl4j.version}</version>
</dependency>
<dependency>
<artifactId>deeplearning4j-nlp</artifactId>
</dependency>
<!-- ParallelWrapper & ParallelInference live here -->
<dependency>
<artifactId>deeplearning4j-parallel-wrapper_${scala.binary.version}</artifactId>
</dependency>
<!-- Arbiter - used for hyperparameter optimization (grid/random search) -->
<dependency>
<artifactId>arbiter-deeplearning4j</artifactId>
<version>${arbiter.version}</version>
</dependency>
<!-- Used in the feedforward/classification/MLP* and feedforward/regression/RegressionMathFunctions example -->
<dependency>
<groupId>jfree</groupId>
<artifactId>jfreechart</artifactId>
<version>${jfreechart.version}</version>
</dependency>
<dependency>
<groupId>org.jfree</groupId>
<artifactId>jcommon</artifactId>
<version>${jcommon.version}</version>
</dependency>
<!-- Used for downloading data in some of the examples -->
<dependency>
<groupId>org.apache.httpcomponents</groupId>
<artifactId>httpclient</artifactId>
<version>4.3.5</version>
</dependency>
<dependency>
<groupId>ch.qos.logback</groupId>
<artifactId>logback-classic</artifactId>
<version>${logback.version}</version>
</dependency>
</dependencies>
</project>
