When use system.date.jsonEncode to encode a java.util.Date into a json string and put it into an MS-SQSL db, I cannot read the field back out of the string within SQL using the OPENJSON command.
Start with a simple dictionary with dates, converted to a json string:
value = {
"startTime": system.date.getDate(2023, 5, 29),
"endTime": system.date.getDate(2023, 5, 19)
jsonStr = system.util.jsonEncode(value)
Result:
{"startTime":"Thu Jun 29 00:00:00 UTC 2023","endTime":"Mon Jun 19 00:00:00 UTC 2023"}
Literal string on the SQL side for simplicity:
Declare @JSON varchar(max) = '{"startTime": "Thu Jun 29 00:00:00 UTC 2023","endTime": "Mon Jun 19 00:00:00 UTC 2023"}'
SELECT * FROM
OPENJSON (@JSON )
WITH (
startTime datetime2 '$.startTime',
endTime datetime2 '$.endTime'
Result:
Conversion failed when converting date and/or time from character string.
Is there a simple workaround for this short of writing my own version of system.util.jsonEncode()?
A terrible workaround but perhaps system.dataset.formatDates could be useful? Convert the system.date objects into strings (formatted to ISO8601 compliant format, the only acceptable format for machine-to-machine text messages) before the json.Encode.
That's the 'rewrite system.util.jsonEncode()' that I'm trying to avoid.
Hoping there's a way to override the java.util.Date._ str__() or perhaps use an existing open source function.
Convert them to Instant before encoding:
value = {
"startTime": system.date.getDate(2023, 5, 29).toInstant(),
"endTime": system.date.getDate(2023, 5, 19).toInstant()
edit: FWIW, this is barely any different from what @Tim_Carlton suggested.
Yes, thank you both. The more complicated story here is that the original json comes from a third-party system. We do display it in a table in Ignition, so we do have it in a dataset and can manipulate the fields manually, but we are not really in control of the fields or their data types.
We could also write a routine to drill down through the array/dictionary fields to look for data items with the type name 'datetime' and convert the type of each one before calling encode, but I am hoping for something a little more pythonic.
My guess is that system.dataset.formatDates does Exactly that, except for datasets instead of dictionaries.
Oh! Let me clean my glasses - I read that as system.date.format(date, format). Yes, thank you!
