This sounds very odd. Why did you “have” to change the capital “D” to a lowercase “d”? Do you have a 7.2 backup sitting around that you could try and replicate this on to see if it happens again?
Well, I’m looking at your Gateway but I’m not sure what I should be looking at.
You have an authentication profile called “default”. Some of your projects are referencing “default” - these are fine. Some are referencing “Default”: these are broken. Perhaps authentication profile lookup was case insensitive in 7.2, and you’d typed them in inconsistently…
Wrong backup then. That was after I changed everything from “Default”
I really should take a backup before I mess with things.
Like I said, everything was “Default” then I upgraded and everything looked good until you tried to open a project. Then you would get an error about being unable to find the “default” profile even though the project referenced the “Default” profile which did exist.
