The default pack rate multiplier does not work. We have tried 6 as in 6 packages per index and .1667 as in 1 index divided by .1667 = 6 packs. This math does not reflect on the shift counts. What is it used for then?
The actual counts will not be affected by the package count.
I may not have understood what you were looking for when I was speaking with you yesterday.
Please describe what the input and output of the line or cell is so I can have a clearer picture.
Try setting it back to one and look at the production rate and see if it is what you want. If you want to see your outfeed counts relative to the package count then you will need to do the multiplication on an SQL tag.
Regards.
