Hi Everyone,
I’ve been seeing a bunch of “defaultexceptionmapper” error in the gateway log (Ignition 7.9).
if you expand the error details you’ll see these error details. Any help would be much appreciated.
org.apache.wicket.WicketRuntimeException: Exception in rendering component: [HtmlHeaderContainer [Component id = _header_0]]
at org.apache.wicket.Component.internalRenderComponent(Component.java:2562)
at org.apache.wicket.MarkupContainer.onRender(MarkupContainer.java:1491)
at org.apache.wicket.Component.internalRender(Component.java:2365)
at org.apache.wicket.Component.render(Component.java:2293)
at org.apache.wicket.MarkupContainer.renderNext(MarkupContainer.java:1388)
at org.apache.wicket.MarkupContainer.renderAll(MarkupContainer.java:1553)
at org.apache.wicket.Page.onRender(Page.java:884)
at org.apache.wicket.markup.html.WebPage.onRender(WebPage.java:142)
at org.apache.wicket.Page.renderPage(Page.java:1021)
at org.apache.wicket.request.handler.render.WebPageRenderer.renderPage(WebPageRenderer.java:116)
at org.apache.wicket.request.handler.render.WebPageRenderer.respond(WebPageRenderer.java:244)
at org.apache.wicket.core.request.handler.RenderPageRequestHandler.respond(RenderPageRequestHandler.java:165)
at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:814)
at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:253)
at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:210)
at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:281)
at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:188)
at org.apache.wicket.protocol.http.WicketFilter.doFilter(WicketFilter.java:245)
at com.inductiveautomation.ignition.gateway.bootstrap.SRFilter.doFilter(SRFilter.java:80)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1596)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:545)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:590)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1607)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1297)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:485)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1577)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1212)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:59)
at org.eclipse.jetty.server.Server.handle(Server.java:500)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:383)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:547)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:375)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:270)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103)
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:543)
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:398)
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:161)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:388)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:806)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:938)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.NullPointerException: null
at com.inductiveautomation.ignition.gateway.web.pages.BasePage.renderHead(BasePage.java:204)
at org.apache.wicket.Component.renderHead(Component.java:4428)
at org.apache.wicket.Component.renderHead(Component.java:2688)
at org.apache.wicket.markup.renderStrategy.AbstractHeaderRenderStrategy.renderRootComponent(AbstractHeaderRenderStrategy.java:127)
at org.apache.wicket.markup.renderStrategy.ChildFirstHeaderRenderStrategy.renderHeader(ChildFirstHeaderRenderStrategy.java:60)
at org.apache.wicket.markup.html.internal.HtmlHeaderContainer.onComponentTagBody(HtmlHeaderContainer.java:170)
at org.apache.wicket.markup.html.panel.DefaultMarkupSourcingStrategy.onComponentTagBody(DefaultMarkupSourcingStrategy.java:71)
at org.apache.wicket.Component.internalRenderComponent(Component.java:2535)
… 58 common frames omitted
