I note that if I change a session property on a particular PC, the next time that PC loads up a new session, it will remember the session properties and use them again next time.
For example, on a new PC, the session will open in light mode. I can change it to dark mode, and the next time a session is opened on that PC, it will open in dark mode.
How can I make dark mode the default for all new sessions?
That would force it to be dark all the time though, correct?
The theme was just one example - there are about 5-10 session properties that I set up with each new device, but it'd be much easier if I could just set something at the gateway level that says "these are the defaults that each new device uses as a starting point". If on one device the users want a different option, no problem, they can select that - but it just means that anyone who spins up a session on any device will get a familiar environment to start, and if they want to change it, they can.
