It is possible to define a type in paramers in functions?
Something like this:
def __init__(self, execution_ok: int, message=None: str, additional_info=None):
It throws an error in the first : that expected a RPAREN, I suposse it expects to close the definition.
Any idea if this is possible in this version of Jython?
Thanks in advance!
You may try:
def __init__(self, execution_ok, message=None, additional_info=None):
if not isinstance(execution_ok, int):
raise TypeError("execution_ok must be an integer")
if message is not None and not isinstance(message, str):
raise TypeError("message must be a string")
# Function logic here
Jython follows Python 2.x syntax and does not support Python 3.x features such as type hints
