Is there a way to define static value in a cell on different tagpath names? currently all tags pulled in would have the same (Low, High, and Centerline) value. I need to be able to define what those are for each tagpath.
Write a script datasource and iterate through your data and add the values needed in the script datasource, then use that datasource as the table source.
That worked! thanks David.
