We have a jsonString which contains the degree symbol. When we try to decode that string it errors out, see example code and error below.
Should I be encoding the degree symbol differently? I’ve tried many different formats and can’t seem to make anything work.
Code:
deg = '°'
config = [{'degree': deg}]
print config
newConfig = system.util.jsonDecode(str(config))
print newConfig
Error results:
Jython 2.7.1 (default:0df7adb1b397, Jun 30 2017, 19:02:43)
[OpenJDK 64-Bit Server VM (Azul Systems, Inc.)] on java11.0.6
[{'degree': '\xc2\xb0'}]
Java Traceback:
File "<input>", line 6, in <module>
at org.json.JSONTokener.syntaxError(JSONTokener.java:430)
at org.json.JSONTokener.nextString(JSONTokener.java:282)
at org.json.JSONTokener.nextValue(JSONTokener.java:355)
at org.json.JSONObject.<init>(JSONObject.java:201)
at org.json.JSONTokener.nextValue(JSONTokener.java:358)
at org.json.JSONArray.<init>(JSONArray.java:127)
at org.json.JSONArray.<init>(JSONArray.java:160)
at com.inductiveautomation.ignition.common.script.builtin.SystemUtilities.jsonDecode(SystemUtilities.java:427)
org.json.JSONException: org.json.JSONException: Illegal escape. at 15 [character 16 line 1]
at org.python.core.Py.JavaError(Py.java:552)
at org.python.core.Py.JavaError(Py.java:543)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:520)
at org.python.core.PyObject.__call__(PyObject.java:480)
at org.python.core.PyObject.__call__(PyObject.java:484)
at org.python.pycode._pyx106.f$0(<input>:7)
at org.python.pycode._pyx106.call_function(<input>)
at org.python.core.PyTableCode.call(PyTableCode.java:171)
at org.python.core.Py.runCode(Py.java:1614)
at org.python.core.Py.exec(Py.java:1658)
at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:276)
at org.python.util.InteractiveInterpreter.runcode(InteractiveInterpreter.java:131)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:605)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:593)
at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: org.json.JSONException: Illegal escape. at 15 [character 16 line 1]
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
... 19 more
