Delay between repeats in sound player
hello! @paul-griffith is there a way to add a delay between reproductions of the voice message?
Not easily built in to the component.
A few ideas come to mind:
  1. You could simply ‘pad’ your audio clip with silence at the end with an audio editor.
  2. You could set the sound player to ‘ON_TRIGGER’ and use a Signal Generator component to make a square wave with the appropriate duration.
Thanks for the suggestions,
I did that with a timer and almost worked but if the trigger keeps up then it turns into a forever repeat and ts not repeated only the first time. will try using the signal generator . thanks for the helo.
