Delete SQL DUPLICATE LINES BY SCRIPTING
with tabs as
select ROW_NUMBER() over (order by SaleOrder) as RowNum ,
 [SaleOrder]
      ,[Date]
      ,[Pos]
      ,[Remark]
      ,[UpdateTime]
  FROM [NTSplicingSCADA].[dbo].[SalesText]
  delete from tabs
  WHERE RowNum<(SELECT MAX(T2.RowNum)
				From tabs T2
				WHERE tabs.SaleOrder=T2.SaleOrder
				and tabs.Pos=T2.Pos
				and tabs.Remark=T2.Remark
In my SQL table , which always contain many lines they are the same data, I want to delete duplicate lines, I can success in sql environment ,but I want to running it in the ignition by means of scripting to trigger upside SQL logic
querydelete="""
with tabs as
 [SaleOrder]
      ,[Date]
      ,[Pos]
      ,[Remark]
      ,[UpdateTime]
  delete from tabs
				From tabs T2
				and tabs.Pos=T2.Pos
system.db.runQuery(querydelete,'NTSplicingSCADA')
But it report fault
Use system.db.runUpdateQuery() instead.
https://docs.inductiveautomation.com/display/DOC80/system.db.runUpdateQuery
It works , thanks a lot
As an aside, if you want to prevent duplicate rows in the first place, try making an UNIQUE INDEX on the column or columns you want to enforce uniqueness on.
