I have some paths I’ve created but there are extra vertices that I need to delete. How do I do this?
Going into edit mode selecting the vertices and pressing delete deletes the whole object. Can’t see anything in the right click or any other menu.
Not sure why this was locked; but for anyone’s future reference, after you’ve created a path you can use the ‘Path’ tool to remove particular vertices. This is located along the shape toolbar, which defaults to the far-right–hand side of the screen. Once you have this tool active and a shape selected, you can click particular vertices on a path, which will highlight them in blue. Then there are some functions added to the toolbar along the top, one of which will deleted the selected vertices.
