I unzipped the sdk, installed Helios but when I try to compile I get the following error-
“Error running javac.exe compiler”. Googled the error and several hits with no luck. Can you help?
thanks
tim
thanks
tim
Do you have the Java 6 JDK installed? Not the JRE, but the JDK? If so, maybe Eclipse needs to be pointed towards it (Window > Preferences > Java > Installed JREs)
