Deploy Ignition Gateway with Ansible/Chef/Puppet/Powershell DSC or in Kubernetes
Hi Community,
I have been searching on github and on this forum and i cant find any reference how to deploy Ignition Gateway through configuration management software (Ansible/Puppet/Chef/Powershell DSC). Anyone already did it before?
In the other way, since Ignition is based on java, did anyone already tested running it in Kubernetes?
Any feedback regarding this subject?
Deploying it in big scale doing by click click, is dangerous(human factor), a slow process and it is manual process that you automate and even implement CI/CD for it.
And with kubernetes i can scale up and down easily and upgrade gateway ignition without downtime (without restarting it).
You might find inspiration from the Vagrant scripts discussed here:
Well, is about vagrant. But, let see what i can do from there.
Installing stuff through GUIs is time consuming and human-error-prone task. And its java app, it should run without problem in a docker image.
