Deploy ignition on Kubernetes
I was trying to deploy the ingnition into the K8 cluster, and I can't bind the /usr/local/bin/ignition/data with persistent volume, do I need to bind any other path? also while restarting the pod I want to keep the license key same, it will not be working after it used one time, how can I use my key after pod restart? I would like to use the official docker image for the deployment.
