Deploy the Vision Client on Docker for a balena device
Hello everyone,
i'm trying to deploy the Ignition Vision Client on Docker as I would like to run the client on a balena device.
I tried but i get different errors. Is there any example on how to run in on Docker?
I'm trying to launch manually launcher-vision-client-linux.jar and this is what we get:
INFO  [CompositeClassRejectListFilter] [2024/05/13 12:43:36]: Initialization performed successfully
INFO  [CompositeClassRejectListFilter] [2024/05/13 12:43:36]: JVM-wide ObjectInputFilter set up successfully
INFO  [CompositeClassRejectListFilter] [2024/05/13 12:43:36]: Platform serialFilter has 88 pattern(s)
INFO  [ClientLauncher                ] [2024/05/13 12:43:37]: Set initial logging level to INFO
May 13, 2024 12:43:37 PM com.sun.javafx.application.PlatformImpl startup
WARNING: Unsupported JavaFX configuration: classes were loaded from 'unnamed module @6c50245e'
Loading library prism_es2 from resource failed: java.lang.UnsatisfiedLinkError: /root/.openjfx/cache/17.0.2-ea/libprism_es2.so: libGL.so.1: cannot open shared object file: No such file or directory
        at java.base/jdk.internal.loader.NativeLibraries.load(Native Method)
        at java.base/jdk.internal.loader.NativeLibraries$NativeLibraryImpl.open(NativeLibraries.java:384)
        at java.base/jdk.internal.loader.NativeLibraries.loadLibrary(NativeLibraries.java:228)
        at java.base/jdk.internal.loader.NativeLibraries.loadLibrary(NativeLibraries.java:170)
        at java.base/java.lang.ClassLoader.loadLibrary(ClassLoader.java:2389)
        at java.base/java.lang.Runtime.load0(Runtime.java:755)
        at java.base/java.lang.System.load(System.java:1953)
        at com.sun.glass.utils.NativeLibLoader.installLibraryFromResource(NativeLibLoader.java:217)
        at com.sun.glass.utils.NativeLibLoader.loadLibraryFromResource(NativeLibLoader.java:197)
        at com.sun.glass.utils.NativeLibLoader.loadLibraryInternal(NativeLibLoader.java:138)
        at com.sun.glass.utils.NativeLibLoader.loadLibrary(NativeLibLoader.java:54)
        at com.sun.prism.es2.ES2Pipeline.lambda$static$0(ES2Pipeline.java:63)
        at java.base/java.security.AccessController.doPrivileged(AccessController.java:318)
        at com.sun.prism.es2.ES2Pipeline.<clinit>(ES2Pipeline.java:52)
        at java.base/java.lang.Class.forName0(Native Method)
        at java.base/java.lang.Class.forName(Class.java:375)
        at com.sun.prism.GraphicsPipeline.createPipeline(GraphicsPipeline.java:218)
        at com.sun.javafx.tk.quantum.QuantumRenderer$PipelineRunnable.init(QuantumRenderer.java:92)
        at com.sun.javafx.tk.quantum.QuantumRenderer$PipelineRunnable.run(QuantumRenderer.java:125)
        at java.base/java.lang.Thread.run(Thread.java:833)
ERROR [RuntimeException              ] [2024/05/13 12:43:37]: Uncaught exception in thread: main
java.lang.UnsupportedOperationException: Unable to open DISPLAY
        at com.sun.glass.ui.gtk.GtkApplication.lambda$new$6(GtkApplication.java:181)
        at com.sun.glass.ui.gtk.GtkApplication.<init>(GtkApplication.java:179)
        at com.sun.glass.ui.gtk.GtkPlatformFactory.createApplication(GtkPlatformFactory.java:41)
        at com.sun.glass.ui.Application.run(Application.java:146)
        at com.sun.javafx.tk.quantum.QuantumToolkit.startup(QuantumToolkit.java:291)
        at com.sun.javafx.application.PlatformImpl.startup(PlatformImpl.java:293)
        at com.sun.javafx.application.PlatformImpl.startup(PlatformImpl.java:163)
        at com.sun.javafx.application.LauncherImpl.startToolkit(LauncherImpl.java:659)
        at com.sun.javafx.application.LauncherImpl.launchApplication1(LauncherImpl.java:679)
        at com.sun.javafx.application.LauncherImpl.lambda$launchApplication$2(LauncherImpl.java:196)
You can't launch a Vision Client on Docker or in any headless environment. There's no GUI.
Hello Kevin i was thinking on running xserver on another container and use it as a UI for the Vision Client container.
Looks experimental and no longer maintained...
You're in uncharted territory here, I think. Keep chasing down the errors if it's something you really want to pursue.
Start here? It looks like you may be missing some additional system libraries.
Thanks for your message Kevin!
I will keep you posted!
Kevin i just had the Ignition Client running here GitHub - mpous/ignition-visionclient-launcher-balena
Not sure if this is correct as i haven't tested this with Ignition but this is a first step!
