Deploying Ignition: EAM/Import is writing to tag value
Hi all,
At our customer we have dev - test and production environment. We are running into an issue in our deployment cycle and we wonder how other people handle this.
Whenever we try to deploy our tags, using EAM or import/export, the import also writes values to those tags. Going from dev to production is quite a problem, since development could have very different values as the production environment.
How do you handle that issue, where you don't overwrite all values when deploying?
Thanks!
