Derived Tag using runScript in Write Expression errors out, even in simplest case
I am trying to run a script to handle my Write Expression in a Derived tag. I wrote a script that simply returns a value, and call it in the Write Expression, and when I try to change the value of the tag, all I get is
Error writing to setpoint.value: Error_ExpressionEval
I have tried to replace runScript("MyScripts.static_value") with the actual value of static_value, and it works just fine. But I can't seem to get the script to run in the same spot!
def static_value():
    return 0.333
Is this not possible? I can select runScript from the binding popup that comes with the control itself, I am not forcing it into a place it is not to be selected, so I am not sure. The documentation for runScript mentions nothing about not being allowed to use these in a Derived tag.
Also, is there a way to get a more verbose Error_ExpressionEval?
Do you have the gateway scripting project set?
Where do I set this? I can't find anything in Project Properties, nor obviously in the Gateway Config. I changed the "Script Hint Scop" to Gateway to no apparent effect.
https://docs.inductiveautomation.com/display/DOC80/Project+Library#ProjectLibrary-GatewayScriptingProject
That did it, thank you. Hidden in Gateway Settings!
I guess I should just have a single project with all of my scripts?
Generally not. I recommend:
  • an inheritable project with all of your extremely-well-tested generic functions, to be your root "global" project,
  • zero or more inheritable projects (themselves inheriting root) with common GUI elements for sections of your project "tree",
  • a leaf project with all of the functions your tag events need (inheriting from root), to be your global scripting project, and
  • other leaf projects to be actual UIs and leaf projects to encapsulate complex gateway-only tasks.
