I have recently installed the WebDev module to try and develop an HTML based mobile app for a project in Ignition.
I have two testing environments set up, a Windows 7 gateway running Ignition 7.8.4, and a Debian gateway running Ignition 7.8.4.
My WebDev directory contains a couple of HTML pages, a jquery.js source for scripting and some python resources for server side code.
Everything is running fine on my Windows 7 gateway, but when I copy the exact same files over to my Debian gateway i get a error in the gateway console as follows:
ERROR 11:24:02 AM Dispatch Deserializing resource failed.
java.lang.NullPointerException
at com.inductiveautomation.webdev.gateway.handlers.PythonResourceHandler.<init>(PythonResourceHandler.java:125)
at com.inductiveautomation.webdev.gateway.servlets.WebDevDispatch$ProjectDispatcher$1.load(WebDevDispatch.java:336)
at com.inductiveautomation.webdev.gateway.servlets.WebDevDispatch$ProjectDispatcher$1.load(WebDevDispatch.java:272)
at com.google.common.cache.LocalCache$LoadingValueReference.loadFuture(LocalCache.java:3527)
at com.google.common.cache.LocalCache$Segment.loadSync(LocalCache.java:2319)
at com.google.common.cache.LocalCache$Segment.lockedGetOrLoad(LocalCache.java:2282)
at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2197)
at com.google.common.cache.LocalCache.get(LocalCache.java:3937)
at com.google.common.cache.LocalCache.getOrLoad(LocalCache.java:3941)
at com.google.common.cache.LocalCache$LocalLoadingCache.get(LocalCache.java:4824)
at com.inductiveautomation.webdev.gateway.servlets.WebDevDispatch$ProjectDispatcher.get(WebDevDispatch.java:366)
at com.inductiveautomation.webdev.gateway.servlets.WebDevDispatch.doGet(WebDevDispatch.java:132)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:687)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:85)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:837)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:583)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1160)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:511)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1092)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:52)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134)
at org.eclipse.jetty.server.Server.handle(Server.java:518)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:308)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:244)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:273)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:95)
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93)
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceAndRun(ExecuteProduceConsume.java:246)
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:156)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:654)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:572)
at java.lang.Thread.run(Thread.java:745)
This occurs when i try and execute an Ajax GET method.
I have spent about a day trying to get to the bottom of it, and I am fairly sure its not an issue with my code or syntax, as the exact same resources are working in my Windows 7 gateway.
The strange thing is, I had an earlier version of the same code working on my Debian gateway. And i can’t recall any changes i could have done to affect the gateway.
I’m pretty new to WebDev stuff so any help would be much appreciated.
