Design flow for control room LED and buzzer via Ignition
Hi all,
I’m integrating an IFM DV2130 (LED + buzzer) into Ignition via Modbus TCP. I already have a device connection and a UDT that exposes the lamp/buzzer controls (buzzer enable, buzzer sound selection, LED states, etc.).
What I’m trying to build now is an operator-configurable alarm routing system:
  • Operators should be able to choose which alarms in the plant will trigger the DV2130.
  • Example: they may want a Tank High Level alarm in one area to trigger the light/buzzer, or a specific pump alarm to trigger it.
  • Ideally the operator can “select from a list” of available alarm sources, and the DV2130 logic reacts accordingly (without me hardcoding every alarm/tag).
What’s the best-practice approach in Ignition to implement this?
Specifically, what pattern would you recommend for a tag/alarm trigger system where operators can configure which alarm events drive the stacklight/buzzer (and optionally map severity/state → color + sound)?
I’m considering dynamically building an expression/logic tag based on the operator’s selections, but I’m not sure if that’s the right approach.
Any recommended architecture (tag event scripts, alarm journal queries, alarm pipelines, grouped “OR” tags, database-driven mapping, etc.) would be appreciated.
Thanks in advance.
Is there only one buzzer or are there multiple in different areas? I ask because if it's multiple and they can assign alarms to multiple buzzers then it complicates things slightly.
I'd probably just make an alarm pipeline that triggers the buzzer and then in each alarm have the notification-pipeline values set by a string tag in the UDT. Then when they select that Tank High level as active it sets the string to be the name of the buzzer pipeline so it activates that.
The UI to control what buzzes and doesn't is a more broad set of options. Personally I'd put it on the faceplate for each device right by the alarm indication and just have a tick box to enable the buzzer. Though if there is a large number of tags and they have an operational reason for constantly turning many buzzers on and off, perhaps as part of maintenance, then I'd build a table where they can scroll through the alarms and filter via text bar then select and enable/disable from that. But that's going to require more effort on your part to script all that.
There is only one led/buzzer at the moment.
I went your suggestion and after a few hours of development got it working.
Have an Active and Clear Script block that increments or decrements a counter tags for amber, red and buzzer. Red>Amber>Green
Active Script Block
    # Alarm Pipeline Script Block (Active)
    log = system.util.getLogger("led_buzzer_pipeline")
    BASE = "[default]DV2103"
    CNT_RED   = BASE + "/alarm_pipeline/cntRed"
    CNT_AMBER = BASE + "/alarm_pipeline/cntAmber"
    BUZ_CNT   = BASE + "/alarm_pipeline/buzzerCnt"
    WORD_TAG  = BASE + "/cfg/control_word"   # single INT register
    # ---------------- helpers ----------------
    def clamp0(v):
        try:
            v = int(v or 0)
            return v if v > 0 else 0
        except:
            return 0
    def priority_name(ev):
        try:
            return str(ev.getPriority()).lower()
        except:
            try:
                return str(ev["priority"]).lower()
            except:
                return ""
    def bucket_for_priority(p):
        if "critical" in p or "high" in p:
            return "RED"
        if "medium" in p or "low" in p:
            return "AMBER"
        return None
    def buzzer_enabled(ev):
        val = None
        try:
            val = ev.get("buzzer_enable")
        except:
            pass
        if val is None:
            return False
        s = str(val).strip().lower()
        return s in ("true", "1", "yes", "y", "on")
    def decode_led_int_and_buzzer(control_word):
        w = int(control_word or 0)
        red   = (w >> 0) & 1
        amber = (w >> 1) & 1
        green = (w >> 2) & 1
        if red:
            led_int = 1
        elif amber:
            led_int = 2
        elif green:
            led_int = 3
        else:
            led_int = 0
        buz_on = ((w >> 8) & 1) == 1
        return led_int, buz_on
    def desired_led_int(cnt_red, cnt_amber):
        if cnt_red > 0:
            return 1
        if cnt_amber > 0:
            return 2
        return 3
    # ---------------- logic ----------------
    p = priority_name(event)
    bucket = bucket_for_priority(p)
    buzz = buzzer_enabled(event)
    vals = system.tag.readBlocking([CNT_RED, CNT_AMBER, BUZ_CNT, WORD_TAG])
    cnt_red   = clamp0(vals[0].value)
    cnt_amber = clamp0(vals[1].value)
    buz_cnt   = clamp0(vals[2].value)
    cur_word  = vals[3].value
    # increment for activating alarm
    if bucket == "RED":
        cnt_red += 1
    elif bucket == "AMBER":
        cnt_amber += 1
    if buzz and bucket in ("RED", "AMBER"):
        buz_cnt += 1
    new_led = desired_led_int(cnt_red, cnt_amber)
    new_buz = (buz_cnt > 0)
    # persist counters
    system.tag.writeBlocking([CNT_RED, CNT_AMBER, BUZ_CNT], [cnt_red, cnt_amber, buz_cnt])
    # compare against real device state
    cur_led, cur_buz = decode_led_int_and_buzzer(cur_word)
    if new_led != cur_led or new_buz != cur_buz:
        ifm.write_outputs_atomic(WORD_TAG, led_int=new_led, buzzer_on=new_buz)
Clear Script Block
    # Alarm Pipeline Script Block (Clear / Inactive)
    def clamp0(v):
        try:
            v = int(v or 0)
        except:
            return 0
        try:
        except:
            try:
            except:
                return ""
        # High/Critical -> Red, Medium/Low -> Amber, others ignored
            return "RED"
            return "AMBER"
        return None
        # custom alarm property: buzzer_enable (string "true"/"false")
        val = None
        try:
        except:
            pass
        if val is None:
            return False
        """Return (led_int, buz_on) from control word bits."""
        red   = (w >> 0) & 1
        # led_int mapping: 1=Red, 2=Amber, 3=Green (choose priority if multiple bits)
        if red:
            led_int = 1
        elif amber:
            led_int = 2
        elif green:
            led_int = 3
        else:
            led_int = 0  # none on
        # 1=Red, 2=Amber, 3=Green
        if cnt_red > 0:
            return 1
        if cnt_amber > 0:
            return 2
        return 3
    # decrement for clearing alarm
    if bucket == "RED":
        cnt_red = clamp0(cnt_red - 1)
        cnt_amber = clamp0(cnt_amber - 1)
        buz_cnt = clamp0(buz_cnt - 1)
    # persist counters
The only annoying thing is that the ifm io master link does not support masked bit writes so I cannot write to multiple bits at the same time.
