I have 7.8 Ignition on a pretty basic application.
I have experienced, ONLY on a remote client view (and also at Designer) the application exit out randomly without any prompt. Attached is the whole java log, that gets created right after each “crash”.
I have uninstall completely Java, re-install and still same symptom…
Any ideas are welcome,
Thanks in advance.
A fatal error has been detected by the Java Runtime Environment:
EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x0000000000000000, pid=2188, tid=4664
JRE version: Java™ SE Runtime Environment (8.0_73-b02) (build 1.8.0_73-b02)
Java VM: Java HotSpot™ 64-Bit Server VM (25.73-b02 mixed mode windows-amd64 compressed oops)
Problematic frame:
C 0x0000000000000000
Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
If you would like to submit a bug report, please visit:
I have also experienced this. I have experienced this when running a client and a designer on my workstation for both a client and a test Ignition system. No warning and no prompt.
The production server is running an earlier version of Java 8, but my workstation and the test gateway are running 8 update 77.
