Designer: Code editor extremely slow if typing alphanumerics
Hello!
I’m testing out an upgrade from Ignition 7.3.4 to 7.5.6. The problem I’m facing is that the code editor (Python) in the Designer is now inpractically slow, if typing any letters or numbers. Otherwise it works fine: For example, cut and paste and hitting Enter key repeatedly.
The effect is significant, I can’t use the code editor for programming, only for text block handling.
My OS is Xubuntu and this problem reproduces with both, Java 6 and Java 7 equally.
A possibly userful lead I got, is that every time I break the execution of the Designer, the stack (of the thread likely in question) looks like below. Seems like a race condition of some sort:
Cheers,
cgz
Thread [AWT-EventQueue-0] (Suspended)
	Unsafe.park(boolean, long) line: not available [native method]
	LockSupport.park(Object) line: 156
	AbstractQueuedSynchronizer$ConditionObject.await() line: 1987
	SunToolkit.awtLockWait() line: 248
	XToolkit.getCurrentServerTime() line: 1189
	XClipboard.setContentsNative(Transferable) line: 69
	XClipboard(SunClipboard).setContents(Transferable, ClipboardOwner) line: 93
	CodeEditorFactory$1(CodeEditor).selectionChanged(SelectionEvent) line: not available
	DefaultSelectionModel.fireSelectionChangeEvent(int, int, int, int) line: not available
	DefaultSelectionModel.setSelection(int, int) line: not available
	CodeEditorFactory$1(CodeEditor).a(int, int, boolean, boolean) line: not available
	CodeEditorFactory$1(CodeEditor).select(int, int, boolean) line: not available
	CodeEditorFactory$1(CodeEditor).select(int, int) line: not available
	CodeEditor$p_.insertUpdate(DocumentEvent) line: not available
	SyntaxDocument(AbstractDocument).fireInsertUpdate(DocumentEvent) line: 185
	SyntaxDocument.fireInsertUpdate(DocumentEvent) line: not available
	SyntaxDocument(AbstractDocument).handleInsertString(int, String, AttributeSet) line: 734
	SyntaxDocument(AbstractDocument).insertString(int, String, AttributeSet) line: 693
	SyntaxDocument(PlainDocument).insertString(int, String, AttributeSet) line: 114
	a.insertStringAtCaret(CodeEditor, String, boolean, boolean) line: not available
	CodeEditorFactory$1(CodeEditor).c(String) line: not available
	CodeEditorFactory$1(CodeEditor).b(String) line: not available
	CodeEditorFactory$1(CodeEditor).insertChar(String) line: not available
	InputHandler$bb_.actionPerformed(ActionEvent) line: not available
	DefaultInputHandler(InputHandler).executeAction(Action, Object, String) line: not available
	DefaultInputHandler(InputHandler).keyTyped(KeyEvent) line: not available
	CodeEditorFactory$1(CodeEditor).processKeyEvent(KeyEvent) line: not available
	CodeEditorFactory$1(Component).processEvent(AWTEvent) line: 6067
	CodeEditorFactory$1(Container).processEvent(AWTEvent) line: 2039
	CodeEditorFactory$1(Component).dispatchEventImpl(AWTEvent) line: 4653
	CodeEditorFactory$1(Container).dispatchEventImpl(AWTEvent) line: 2097
	CodeEditorFactory$1(Component).dispatchEvent(AWTEvent) line: 4481
	DefaultKeyboardFocusManager(KeyboardFocusManager).redispatchEvent(Component, AWTEvent) line: 1836
	DefaultKeyboardFocusManager.dispatchKeyEvent(KeyEvent) line: 712
	DefaultKeyboardFocusManager.preDispatchKeyEvent(KeyEvent) line: 990
	DefaultKeyboardFocusManager.typeAheadAssertions(Component, AWTEvent) line: 855
	DefaultKeyboardFocusManager.dispatchEvent(AWTEvent) line: 676
	ScriptPlayground(Component).dispatchEventImpl(AWTEvent) line: 4525
	ScriptPlayground(Container).dispatchEventImpl(AWTEvent) line: 2097
	ScriptPlayground(Window).dispatchEventImpl(AWTEvent) line: 2482
	ScriptPlayground(Component).dispatchEvent(AWTEvent) line: 4481
	EventQueue.dispatchEventImpl(AWTEvent, Object) line: 648
	EventQueue.access$000(EventQueue, AWTEvent, Object) line: 84
	EventQueue$1.run() line: 607
	EventQueue$1.run() line: 605
	AccessController.doPrivileged(PrivilegedAction<T>, AccessControlContext) line: not available [native method]
	AccessControlContext$1.doIntersectionPrivilege(PrivilegedAction<T>, AccessControlContext, AccessControlContext) line: 87
	AccessControlContext$1.doIntersectionPrivilege(PrivilegedAction<T>, AccessControlContext) line: 98
	EventQueue$2.run() line: 621
	EventQueue$2.run() line: 619
	EventQueue.dispatchEvent(AWTEvent) line: 618
	EventDispatchThread.pumpOneEventForFilters(int) line: 269
	EventDispatchThread.pumpEventsForFilter(int, Conditional, EventFilter) line: 184
	EventDispatchThread.pumpEventsForHierarchy(int, Conditional, Component) line: 174
	EventDispatchThread.pumpEvents(int, Conditional) line: 169
	EventDispatchThread.pumpEvents(Conditional) line: 161
	EventDispatchThread.run() line: 122
I have a feeling this is some sort of undesired interplay with Swing and Xfce (which we do not test on or support).
As you probably guessed, this is not a problem on any OSes that we have tested on. Have you tried another window manager? You might also see if OpenJDK performs any differently.
