Designer Confirmation Exit GUI Bug with 4k Monitor
Hi all,
I'm running two 4k monitors and one 1080p laptop screen. When trying to close the designer , the "Confirm Exit" popup GUI is clipping off the buttons.
This issue doesn't occur if I use1080p monitors.
Is there a way to fix this without having to change my monitor resolutions?
Are you using scaling on the 4k monitors? If so, try using only 100% or 200%, nothing in between.
I used 200% and had the same issue. If i lower it to 100% it was clickable but 100% on 4k is not good to work with. :slight_smile:
