Designer couldn't able to open after "Verifying Signature of Designer" popup
When I open Designer launcher i can see my designer but once i click on designer a popup of "verifying signature of designer" comes and get disappear and nothing happen anything
I have attached log file also
Installed version are ignition v8.1.44 and Designer Launcher v1.1.44
designerlauncher.log (2.3 KB)
please help out for solution
Copy this and run it directly in a terminal / cmd prompt:
C:\Users\dell\AppData\Roaming\Inductive Automation\Designer Launcher\jre\bin\java.exe -classpath C:\Users\dell\.ignition\cache\resources\platform\launchclient.jar\000000002CE86F06\launchclient.jar -Djavaws.sr.gateway.addr.0=http://localhost:8088 -Djavaws.sr.launchts=1732088228259 -Djavaws.sr.main=com.inductiveautomation.ignition.designer.DesignerStartupHook -Djavaws.sr.platform.edition= -Djavaws.sr.platform.plugins= -Xms64M -Xmx1024M -Djavaws.sr.memory.init=64M -Djavaws.sr.memory.max=1024M --add-opens=java.desktop/java.awt=ALL-UNNAMED --add-opens=java.desktop/java.awt.event=ALL-UNNAMED --add-opens=java.desktop/javax.swing=ALL-UNNAMED --add-opens=java.desktop/javax.swing.tree=ALL-UNNAMED --add-opens=java.desktop/javax.swing.plaf=ALL-UNNAMED --add-opens=java.desktop/javax.swing.plaf.basic=ALL-UNNAMED --add-opens=java.desktop/javax.swing.plaf.synth=ALL-UNNAMED --add-opens=java.base/java.lang=ALL-UNNAMED --add-opens=java.base/java.util=ALL-UNNAMED --add-exports=java.desktop/com.apple.eawt=ALL-UNNAMED --add-exports=java.desktop/com.sun.awt=ALL-UNNAMED --add-exports=java.desktop/com.sun.java.swing.plaf.windows=ALL-UNNAMED --add-exports=java.desktop/sun.awt=ALL-UNNAMED --add-exports=java.desktop/sun.awt.image=ALL-UNNAMED --add-exports=java.desktop/sun.awt.shell=ALL-UNNAMED --add-exports=java.desktop/sun.awt.windows=ALL-UNNAMED --add-exports=java.desktop/sun.swing=ALL-UNNAMED --add-exports=java.desktop/sun.swing.plaf.synth=ALL-UNNAMED --add-exports=java.desktop/sun.swing.table=ALL-UNNAMED --add-exports=java.desktop/sun.print=ALL-UNNAMED --add-exports=java.base/sun.security.action=ALL-UNNAMED -Dsun.java2d.d3d=false -Dsun.java2d.noddraw=false -Djavaws.sr.screen=0 -Djavaws.sr.scope=D com.inductiveautomation.ignition.client.launch.BootstrapSwing
Then copy all the output from that and share it.
Now I can use designer; actually, I reinstalled both designer and ignition software. Also, I allow to private network OpenJDK platform binary.
At last, I restart my system.
Thanks, Kevin, for the response, but could you explain why it happened? Any possibilities?
Do we need restart system after installations ?
Not normally. Don't know what happened.
Okay
