I get the following error trying to load one of my projects in the designer.
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Gateway Error 500: Unable to read response from Gateway.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:236)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:304)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:206)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:197)
at com.inductiveautomation.ignition.designer.gateway.DTGatewayInterface.loadProject(DTGatewayInterface.java:294)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$ProjectOpenTask.run(IgnitionDesigner.java:947)
at com.inductiveautomation.ignition.client.util.gui.ProgressDialog$TaskRunner.run(ProgressDialog.java:208)
at java.lang.Thread.run(Unknown Source)
Caused by: org.xml.sax.SAXParseException: The end-tag for element type "Response" must end with a '>' delimiter.
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:302)
... 6 more
Ignition v7.0.1 (b4461)
Java: Sun Microsystems Inc. 1.6.0_11
