Designer Fails To Start Perspective Module
I am running Ignition 8.3 and when I open the Designer, any perspective options do not exist. When looking at the designer logs, I see the following error
11:12:11.194 [WebSocket@1596404008-50] INFO com.inductiveautomation.ignition.client.gateway_interface.GatewayConnectionManager -- WebSocket session is connected
11:12:11.554 [Designer-Startup] INFO designer.main -- Downloading... [+0]
11:12:11.873 [Designer-Startup] INFO designer.main -- Cleanup... [+319]
11:12:11.879 [Designer-Startup] INFO designer.main -- Initializing UI... [+325]
11:12:11.980 [DesignerExecEngine-1] INFO tags.subscriptions -- Changing connected quality to 'Good'
11:12:21.342 [Designer-Startup] INFO designer.main -- Starting module: Perspective [+9788]
11:12:22.620 [Designer-Startup] INFO Perspective.Designer -- Starting up Perspective module.  Mode: Activated
11:12:23.132 [Designer-Startup] ERROR designer.JXBrowserUtil -- Failed to start Browser Engine with options
com.teamdev.jxbrowser.engine.EngineOptions:
autoplayEnabled: false
chromiumDir: C:\Users\$USER\.ignition\cache\resources\jxbrowser\8.12.1
chromiumSwitches: [ ]
diskCacheSize:
fileAccessFromFilesAllowed: false
isGpuDisabled: false
isIncognitoEnabled:true
language:en-us
passwordStore:
remoteDebugginPort: 9222
renderingMode: OFF_SCREEN
isSandboxDisabled: false
secureOriginWhitelist: [ ]
isTouchMenuEnabled: false
userAgent:
userDataDir:C:\Users\$USER\AppData\Local\Temp\JxBrowser-UserData-558af02d-618a-4645-8e5a-12d613823f1b
webSecurityDisabled: false
com.teamdev.jxbrowser.engine.ChromiumProcessStartupFailureException: Process exit code: 0
at com.teamdev.jxbrowser.engine.internal.EngineImpl.newInstance(EngineImpl.java:227)
at com.teamdev.jxbrowser.engine.Engine.newInstance(Engine.java:163)
at com.inductiveautomation.ignition.client.util.JxBrowserUtil.lambda$getOrCreateEngine$2(JxBrowserUtil.java:352)
at com.inductiveautomation.ignition.client.util.JxBrowserUtil.runResourceLockedAction(JxBrowserUtil.java:567)
at com.inductiveautomation.ignition.client.util.JxBrowserUtil.getOrCreateEngine(JxBrowserUtil.java:352)
at com.inductiveautomation.ignition.client.util.JxBrowserUtil.getOrCreateEngine(JxBrowserUtil.java:431)
at com.inductiveautomation.perspective.designer.DesignerHook.startup(DesignerHook.java:233)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$LoadedModule.startup(IgnitionDesigner.java:2004)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.startupModule(IgnitionDesigner.java:1200)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.loadProject(IgnitionDesigner.java:1003)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$StartupProjectDialogHandler.lambda$new$2(IgnitionDesigner.java:2048)
11:12:23.134 [Designer-Startup] INFO designer.main -- Starting module: Vision [+11580]
11:12:23.751 [Designer-Startup] ERROR designer.JXBrowserUtil -- Failed to start Browser Engine with options
diskCacheSize:
language:en-us
passwordStore:
userAgent:
userDataDir:C:\Users\$USER\AppData\Local\Temp\JxBrowser-UserData-477a405f-8e5c-4791-8e34-c42712ac105c
at com.inductiveautomation.webbrowser.BrowserInstanceManager.startup(BrowserInstanceManager.java:36)
at com.inductiveautomation.factorypmi.application.FPMIApp.createApp(FPMIApp.java:335)
at com.inductiveautomation.factorypmi.designer.model.VisionDesignerImpl.createRoot(VisionDesignerImpl.java:711)
at com.inductiveautomation.factorypmi.designer.model.VisionDesignerImpl.startup(VisionDesignerImpl.java:371)
11:12:23.752 [Designer-Startup] ERROR WebBrowser -- BrowserEngine was not initialized. Web Browser Component can not start!
11:12:24.072 [ForkJoinPool.commonPool-worker-1] INFO designer.IdpDesignerSplash -- IdP Proxy Web Server shut down in 20 seconds
11:12:25.289 [Designer-Startup] INFO designer.main -- Starting module: SFC [+13735]
11:12:25.877 [Designer-Startup] INFO designer.main -- Starting module: Event Streams [+14323]
11:12:25.969 [Designer-Startup] INFO designer.main -- Starting module: Reporting [+14415]
11:12:26.051 [Designer-Startup] INFO reporting.Designer -- Starting up Reporting Module. Mode: Trial
11:12:26.252 [Designer-Startup] INFO designer.main -- Starting module: Symbol Factory [+14698]
11:12:26.255 [Designer-Startup] INFO designer.main -- Starting module: Alarm Notification [+14701]
11:12:26.382 [Designer-Startup] INFO designer.main -- Starting module: OPC-UA [+14828]
11:12:26.382 [Designer-Startup] INFO designer.main -- Starting module: Enterprise Administration [+14828]
11:12:26.407 [Designer-Startup] INFO designer.main -- Starting module: Legacy DNP3 Driver [+14853]
11:12:26.407 [Designer-Startup] INFO designer.main -- Starting module: Historian Core [+14853]
11:12:26.407 [Designer-Startup] INFO designer.main -- Starting module: SQL Bridge [+14853]
11:12:26.721 [Designer-Startup] INFO designer.main -- Starting module: Kafka Connector [+15167]
11:12:26.728 [Designer-Startup] INFO designer.main -- Starting module: WebDev [+15174]
11:12:26.747 [Designer-Startup] INFO designer.main -- Initializing Scripting... [+15193]
11:12:26.805 [Designer-Startup] INFO designer.main -- Initializing UI... [+15251]
11:12:26.810 [Designer-Startup] INFO com.inductiveautomation.ignition.designer.querybrowser.QueryBrowser -- No default datasource set for project. Set default in gateway and relaunch project.
The designer shows no perspective module
I have tried to clear the cache at the location shown in the logs, but no change. When running a 8.1 designer/server, the perspective module is there
The Perspective module is missing because JXBrowser is failing to start.
The most frequent cause for this is AV/security software. Ignition 8.3 includes a newer version of JXBrowser/Chromium than 8.1 currently has, and it could be that this version has some false positive, some real CVE associated with it that the security software objects to, is missing from a whitelist your IT added the previous version to, etc...
Would this be expected upgrading from 8.3.2 to 8.3.3?
I’m on the same machine that ran 8.3.0,1, & 2. Today, I upgraded the gateway to 8.3.3 and my designer launcher to 1.3.3.
  • The Perspective module is activated and the gateway is licensed.
  • My Perspective project runs in the browser, but I’ve lost the ability to edit it.
  • I’m running on Ubuntu with docker compose.
16:42:12.539 [Designer-Startup] INFO designer.main -- Downloading... [+0]
16:42:13.109 [Designer-Startup] INFO designer.main -- Cleanup... [+571]
16:42:13.121 [Designer-Startup] INFO designer.main -- Initializing UI... [+583]
16:42:13.213 [DesignerExecEngine-1] INFO tags.subscriptions -- Changing connected quality to 'Good'
16:42:18.060 [ForkJoinPool.commonPool-worker-1] INFO designer.IdpDesignerSplash -- IdP Proxy Web Server shut down in 20 seconds
16:42:20.605 [Designer-Startup] INFO designer.main -- Starting module: Vision [+8067]
16:42:21.862 [Designer-Startup] ERROR designer.JXBrowserUtil -- Failed to start Browser Engine with options
  chromiumDir: C:\Users\WillBaker\.ignition\cache\resources\jxbrowser\8.12.1
  chromiumSwitches: []
  diskCacheSize: <unknown>
  language:en-us
  passwordStore: <unknown>
  secureOriginWhitelist: []
  userAgent: <unknown user agent value>
  userDataDir:C:\Users\WILLBA~1\AppData\Local\Temp\JxBrowser-UserData-4ed10a3c-62ca-4c9b-8378-6c30dc285dfd
	at com.inductiveautomation.ignition.client.util.JxBrowserUtil.lambda$getOrCreateEngine$2(JxBrowserUtil.java:357)
	at com.inductiveautomation.ignition.client.util.JxBrowserUtil.runResourceLockedAction(JxBrowserUtil.java:610)
	at com.inductiveautomation.ignition.client.util.JxBrowserUtil.getOrCreateEngine(JxBrowserUtil.java:357)
	at com.inductiveautomation.ignition.client.util.JxBrowserUtil.getOrCreateEngine(JxBrowserUtil.java:438)
	at com.inductiveautomation.webbrowser.BrowserInstanceManager.startup(BrowserInstanceManager.java:37)
	at com.inductiveautomation.factorypmi.application.FPMIApp.createApp(FPMIApp.java:327)
	at com.inductiveautomation.factorypmi.designer.model.VisionDesignerImpl.createRoot(VisionDesignerImpl.java:761)
	at com.inductiveautomation.factorypmi.designer.model.VisionDesignerImpl.startup(VisionDesignerImpl.java:383)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner$LoadedModule.startup(IgnitionDesigner.java:2038)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner.startupModule(IgnitionDesigner.java:1226)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner.loadProject(IgnitionDesigner.java:1017)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner$StartupProjectDialogHandler.lambda$new$2(IgnitionDesigner.java:2083)
16:42:21.868 [Designer-Startup] ERROR WebBrowser -- BrowserEngine was not initialized. Web Browser Component can not start!
16:42:26.465 [Designer-Startup] INFO designer.main -- Starting module: Perspective [+13927]
16:42:29.321 [Designer-Startup] INFO Perspective.Designer -- Starting up Perspective module.  Mode: Activated
16:42:29.653 [Designer-Startup] ERROR designer.JXBrowserUtil -- Failed to start Browser Engine with options
  language:en-us
  userDataDir:C:\Users\WILLBA~1\AppData\Local\Temp\JxBrowser-UserData-edb812af-01ac-4d63-8628-f2b40e1b04cc
	at com.inductiveautomation.perspective.designer.DesignerHook.startup(DesignerHook.java:236)
16:42:29.766 [Designer-Startup] INFO designer.main -- Starting module: Event Streams [+17228]
16:42:30.067 [Designer-Startup] INFO designer.main -- Starting module: Reporting [+17529]
16:42:30.182 [Designer-Startup] INFO reporting.Designer -- Starting up Reporting Module. Mode: Activated
16:42:30.590 [Designer-Startup] INFO designer.main -- Starting module: Symbol Factory [+18052]
16:42:30.595 [Designer-Startup] INFO designer.main -- Starting module: Alarm Notification [+18057]
16:42:30.815 [Designer-Startup] INFO designer.main -- Starting module: OPC-UA [+18277]
16:42:30.815 [Designer-Startup] INFO designer.main -- Starting module: Enterprise Administration [+18277]
16:42:30.873 [Designer-Startup] INFO designer.main -- Starting module: Historian Core [+18335]
16:42:30.874 [Designer-Startup] INFO designer.main -- Starting module: SQL Bridge [+18336]
16:42:31.443 [Designer-Startup] INFO designer.main -- Initializing Scripting... [+18905]
16:42:31.829 [Designer-Startup] INFO designer.main -- Initializing UI... [+19291]
I found this post and it resolved my issue: Perspective Missing in Project Browser - #13 by paul-griffith
Our IT department uninstalled Crowdstrike from my PC and I relaunched the designer, but the error message was still there. Are there any other recommended things to try?
Interesting update
It seems that running Ignition 8.3.1 or any version after that causes this issue. But if I run 8.3.0, perspective shows up as expected in the designer. I also attached a screenshot of 8.3.4 to verify the issue still exists in the newest released version. All these instances were ran as a container on my local laptop.
Screenshot of Ignition 8.3.1 designer
Screenshot of Ignition 8.3.0 designer
Screenshot of Ignition 8.3.4 designer
JXBrowser (Chromium) got a huge upgrade in 8.3.0 -> 8.3.1 - version 8.5.0 to 8.12.1.
Got it working! But it seems like a workaround.
First, I enabled jxBrowser debugging via the JVM arguments
-Dignition.client.jxBrowser.logLevel=DEBUG
That gave me the following error in the log
23:28:12.383 DEBUG [Chromium] [51508:23944:0417/162812.383:ERROR:chrome\browser\chrome_browser_main_win.cc:1025] Since version 138, Chromium launched with admin privileges will automatically remove the admin permissions and restart. The library does not support Chromium restarts. If you need to keep the admin permissions, use the `--do-not-de-elevate` switch.
23:28:12.418 DEBUG Chromium process exit code: 0
My installation is not set to run as admin, so I added the flag it says in the error to the same JVM arguments in the launcher
-Dignition.chromium.switch.do-not-de-elevate
And success! The designer is showing the perspective module now
Thank you so much!!!!!!!. My issue was resolved.:partying_face:
How did you add these JVM arguments? I have been trying to add them to my designer. I tried adding the following arguments to my design launcher, but I am not sure if I am doing something wrong
-Dignition.client.jxBrowser.logLevel=DEBUG;-Dignition.chromium.switch.do-not-de-elevate;-Dignition.chromium.switch.sandbox=false;
Are you configuring the default settings, or the specific designer connection you're having issues with? Changes to the defaults don't retroactively apply to existing connections. In addition to that, I think the settings are supposed to be one-per-line, not semicolon delimited? Looks like I'm wrong on that.
Apologies for the slow reply. My goal is to configure the default settings I believe so that when I launch say a demo project the Perspective component loads correctly. Currently regardless of what project I run the chromium browser won't start correctly. I am running Ignition 8.3.7.
My work computer also has CrowdStrike which I am sure doesn't help, and I definitely can't uninstall it**. Does this mean that I can only run 8.3.0 in hopes that the chromium version on it will be happy with CrowdStrike? Or, could I get around it with JVM Arguments, but I just don't know how to input them correctly?
If the problem is these two arguments:
You need to apply them individually to every application configuration in your Designer Launcher separately - if you change the defaults, you would have to recreate the application configuration.
Thank you!! I did not realize that there are just default designer JVM Arguments, and that each gateway (or application) has their own as well. Furthermore, after just including -Dignition.chromium.switch.do-not-de-elevate in my JVM arguments the perspective module started working again. Didn't have to delete cache or anything like that (at least per other posts I saw on the topic).
p.s. small correction from my last post, but apparently I am running ignition 8.3.4 rater than 8.3.7
