We recently went to 8.1 RC3 and I noticed some designer issues in Vision. I had 3 power tables on a window that were populated from a Named Query with the polling off. When I added a fourth power table (also populated from a named query with polling off), the designer would refresh and the screen flashed white with every mouse click. The components were able to be selected and moved, but the window would not show them as selected and would flash white then show the new position of the component. It appeared to only be this window with issue. I closed the designer and opened the project again. The issue did not occur until I opened the window with the 4 power tables. When I select and focus on a different window the issue goes away. I checked the gateway and the server is running around 8% CPU and 25% Memory, so it is fine. It appears to be a user interface issue in the designer. Has anyone seen anything similar and know a way to fix this? I realize a simple answer may be to just have < 4 power tables, but I don’t see that as a long term solution.
I closed out of the project and attempted to make a template of the power table. I started having the same issues on the template with only one power table. The issue occurred once I added the configureCell script below. I’ve had similar scripts on power tables before the upgrade, so not sure this is it, but looking for any possibility.
dataset = self.data
dict = {}
if dataset.getValueAt(rowIndex, "Current Job"):
dict['background'] = '#00FF00'
elif dataset.getValueAt(rowIndex, "Hot Part"):
dict['background'] = '#FF0000'
elif dataset.getValueAt(rowIndex, "Critical"):
dict['background'] = '#FFFFF00'
elif rowView % 2 == 0:
dict['background'] = '#FFFFFF'
else:
dict['background'] = '#F7F7F7'
return dict
