Designer-Gateway Comm via RPC
I’ve created a simple example, almost identical to the Design Best Practice in Section 4.6 of the programming guide (p.47). I’ve added a toolbar button that invokes a method, but an error is thrown:
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Gateway Error 500: Unable to read response from Gateway. at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:280) at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:348) at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:219) at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:214) at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.moduleInvoke(GatewayInterface.java:640) at org.test.pkg.designer.TestModuleRPCProxy.invoke(TestModuleRPCProxy.java:15) .. . Caused by: org.xml.sax.SAXParseException: The end-tag for element type "Response" must end with a '>' delimiter. at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source) .. .
The getRPCHandler method is called in the GatewayHook, but I haven’t been able to determine what is happening beyond that.
Is this something that has been encountered before? Any advice on where I might be going wrong?
Thanks,
-JM
Update on this one:
The error was a bit cryptic. The problem was in my build file. I mistakenly packed the jar file of the common project before adding it to the module, so a NoClassDefFoundError occurred when I invoked the RPC method, and didn’t show up in the logs.
Problem solved.
