Designer hangs when replacing Base64 image
I’m using Base64-encoded images. Small images work fine, but when I try to edit and replace them with a new Base64 string, the Designer hangs.
Filesize: 567.31 KB
Encoded: 756.41 KB
Width: 3840 px
Height: 2160 px
  • Characters 774592
Does anyone know how to handle this properly or a better way to update Base64 images?
Thanks in advance!
I don't have a specific answer to your question, but the Right Answer™ is to not use Data URLs at all. They are horribly slow and inefficient. Use one of the following to serve arbitrary content:
  • The webdev module,
  • My Blob Server module to serve from a DB, or
  • A reverse proxy in front of Ignition
Thank you so much for your advice. Your suggestions are beneficial.:+1:
We implemented a WebDev endpoint in the past, works well. Then just call that endpoint.
