Version 8.3.3
In Designer, I create a new Project.
But Project has no Perspective in Designer?
In Gateway ,Module is Active.
Look at the Designer logs for errors. There was probably an error loading the Perspective module on your system.
Call tech support, I had the same problem. There is something that doesn’t get set or unset and you have to fix an ini file or something, I wasn’t watching well enough I had multiple fires at same time.
I installed again!
GWSession 03Mar2026 10:52:08 WebSocket session connected
Log:
GWSession 03Mar2026 10:52:08 WebSocket closed with statusCode='1011', reason='org.eclipse.jetty.websocket.core.exception.WebSocketException: WebSocketEndpoint OPEN method error: Could not initialize cl'
Gateway:
No Vision or Perspective Module
Designer:
Then I download Modules ,Perspective and Vision Module .
I install two modules.
But in the Designer , Vision is show; Perspective isn’t show .
Log:
INFO
InternalDatabase
03Mar2026 11:15:53
Created auto-backup of internal database "config.idb" in 67 ms
INFO
InternalDatabase
03Mar2026 11:15:53
Creating auto-backup of internal database "config.idb"...
INFO
GWSession
03Mar2026 11:15:42
WebSocket closed with statusCode='1000', reason='null'
INFO
GWSession
03Mar2026 11:13:03
WARN
DefaultClientCertificateValidator
03Mar2026 11:11:39
check suppressed: certificate failed hostname check: C=US,ST=CA,L=Folsom,OU=,O=Inductive Automation,CN=Ignition OPC UA Server
INFO
OpcUaClient
03Mar2026 11:11:38
Eclipse Milo OPC UA Client SDK version: 1.0.8
INFO
OpcUaClient
03Mar2026 11:11:38
Eclipse Milo OPC UA Stack version: 1.0.8
INFO
OpcUaClient
03Mar2026 11:11:38
Java version: 17.0.17
INFO
IgnitionOpcUaServer$OpcUaRedundancyListener
03Mar2026 11:11:37
redundancyStateChanged: Role=Independent, Activity level=Active, Project state=Good, History level=Full
INFO
IgnitionGateway
03Mar2026 11:11:37
Ignition[state=STARTING] ContextState = RUNNING
INFO
IgnitionGateway
03Mar2026 11:11:37
Gateway started in 45 seconds.
INFO
ModuleInstance
03Mar2026 11:11:37
Starting up module 'com.inductiveautomation.reporting' v7.3.3 (b2026012009)...
INFO
ModuleInstance
03Mar2026 11:11:37
Starting up module 'com.inductiveautomation.eam' v5.3.3 (b2026012009)...
INFO
ModuleInstance
03Mar2026 11:11:37
Starting up module 'com.inductiveautomation.opcua.drivers.ablegacy' v7.3.3 (b2026012009)...
INFO
ModuleInstance
03Mar2026 11:11:37
Starting up module 'com.inductiveautomation.opcua.drivers.modbus' v8.3.3 (b2026012009)...
INFO
ModuleInstance
03Mar2026 11:11:37
Starting up module 'com.inductiveautomation.opcua.drivers.siemens' v7.3.3 (b2026012009)...
INFO
ModuleInstance
03Mar2026 11:11:37
Starting up module 'com.inductiveautomation.opcua.drivers.logix' v6.3.3 (b2026012009)...
INFO
ModuleInstance
03Mar2026 11:11:37
Starting up module 'com.inductiveautomation.opcua.drivers.dnp3' v5.3.3 (b2026012009)...
INFO
ModuleInstance
03Mar2026 11:11:37
Starting up module 'com.inductiveautomation.opcua.drivers.omron' v5.3.3 (b2026012009)...
INFO
ModuleInstance
03Mar2026 11:11:37
Starting up module 'com.inductiveautomation.sms-notification' v7.3.3 (b2026012009)...
INFO
PerspectiveAuthTokenRecords
03Mar2026 11:11:37
Startup completed in 1 ms
INFO
03Mar2026 11:11:37
Starting up...
INFO
ModuleInstance
03Mar2026 11:11:36
Starting up module 'com.inductiveautomation.perspective' v3.3.3 (b2026012009)...
INFO
VisionClientAuthTokenRecords
03Mar2026 11:11:36
Startup completed in 0 ms
INFO
03Mar2026 11:11:36
Starting up...
INFO
ModuleInstance
03Mar2026 11:11:36
Starting up module 'com.inductiveautomation.vision' v12.3.3 (b2026012009)...
INFO
ModuleHook
03Mar2026 11:11:36
Removed native resource collector shutdown hook.
INFO
ModuleInstance
03Mar2026 11:11:36
Starting up module 'com.inductiveautomation.opccom' v7.3.3 (b2026012009)...
INFO
ModuleInstance
03Mar2026 11:11:36
Starting up module 'com.inductiveautomation.jdbc.postgresql' v1.3.3 (b2026012009)...
INFO
ModuleInstance
03Mar2026 11:11:36
Starting up module 'com.inductiveautomation.jdbc.mariadb' v1.3.3 (b2026012009)...
INFO
ProjectRunner
03Mar2026 11:11:36
Project started.
INFO
ModuleInstance
03Mar2026 11:11:36
Starting up module 'com.inductiveautomation.sqlbridge' v11.3.3 (b2026012009)...
INFO
OpcUaModule
03Mar2026 11:11:36
Routes mounted
INFO
OpcUaServer
03Mar2026 11:11:36
Binding endpoint opc.tcp://127.0.0.1:62541/discovery to localhost:62541 [None/None]
INFO
OpcUaServer
03Mar2026 11:11:36
Binding endpoint opc.tcp://127.0.0.1:62541 to localhost:62541 [Basic256Sha256/SignAndEncrypt]
INFO
OpcUaServer
03Mar2026 11:11:36
Binding endpoint opc.tcp://localhost:62541/discovery to localhost:62541 [None/None]
INFO
OpcUaServer
03Mar2026 11:11:36
Binding endpoint opc.tcp://localhost:62541 to localhost:62541 [Basic256Sha256/SignAndEncrypt]
INFO
OpcUaServer
03Mar2026 11:11:36
Binding endpoint opc.tcp://Taohy-PC:62541/discovery to localhost:62541 [None/None]
INFO
OpcUaServer
03Mar2026 11:11:36
Binding endpoint opc.tcp://Taohy-PC:62541 to localhost:62541 [Basic256Sha256/SignAndEncrypt]
INFO
ModuleInstance
03Mar2026 11:11:36
Starting up module 'com.inductiveautomation.opcua' v10.3.3 (b2026012009)...
INFO
ModuleInstance
03Mar2026 11:11:36
Starting up module 'com.inductiveautomation.sfc' v6.3.3 (b2026012009)...
INFO
ModuleInstance
03Mar2026 11:11:36
Starting up module 'com.inductiveautomation.jdbc.mssql' v1.3.3 (b2026012009)...
INFO
ModuleInstance
03Mar2026 11:11:36
Starting up module 'com.inductiveautomation.alarm-notification' v7.3.3 (b2026012009)...
INFO
ModuleManager
03Mar2026 11:11:36
Starting up modules
INFO
WSChannelManager
03Mar2026 11:11:36
Gateway network channel manager started successfully. Protobuf gzip compression threshold set to 1000 bytes
All the stuff the OP did was irrelevant/a red herring. The Designer uses an embedded version of the Chromium browser called JxBrowser for Perspective. It doesn't use anything from the underlying operating system.
Look in your designer's logs on a startup where you don't see Perspective and you'll see a pretty clear failure/error message. Post that here in a new topic (or contact the support department) and we'll walk you through the general troubleshooting steps. The exact fix is going to vary, because everyone's environment is different, but most of the time it's some kind of IT/security software interfering.
That isn’t a designer log, that is a gateway log, and that is referring to line 12 of a script which would have nothing to do with Perspective not opening in Designer.
What OS are you running the Designer on?
Designer is loding to Windows 11
I havent had a problem when I 1st updated to 8.3. Just in the last week or so.
This is the last failed launch
13:39:26.787 [Designer-Startup] INFO designer.main -- Downloading... [+0]
13:39:26.885 [Designer-Startup] INFO designer.main -- Cleanup... [+98]
13:39:26.890 [Designer-Startup] INFO designer.main -- Initializing UI... [+103]
13:39:26.942 [DesignerExecEngine-1] INFO tags.subscriptions -- Changing connected quality to 'Good'
13:39:28.051 [Designer-Startup] INFO designer.main -- Starting module: Perspective [+1264]
13:39:29.598 [Designer-Startup] INFO Perspective.Designer -- Starting up Perspective module. Mode: Activated
13:49:29.773 [Designer-Startup] ERROR designer.JXBrowserUtil -- Failed to start Browser Engine with options
com.teamdev.jxbrowser.engine.EngineOptions:
autoplayEnabled: false
chromiumDir: C:\Users\borenerj.ignition\cache\resources\jxbrowser\8.12.1
chromiumSwitches:
diskCacheSize:
fileAccessFromFilesAllowed: false
isGpuDisabled: false
isIncognitoEnabled:true
language:en-us
passwordStore:
remoteDebugginPort: 9222
renderingMode: OFF_SCREEN
isSandboxDisabled: false
secureOriginWhitelist:
isTouchMenuEnabled: false
userAgent:
userDataDir:C:\Users\borenerj\AppData\Local\Temp\JxBrowser-UserData-a6830cd2-139a-47e8-991b-b4c204bdc554
webSecurityDisabled: false
com.teamdev.jxbrowser.engine.IpcSetupFailureException: null
at com.teamdev.jxbrowser.engine.internal.EngineImpl.newInstance(EngineImpl.java:201)
at com.teamdev.jxbrowser.engine.Engine.newInstance(Engine.java:163)
at com.inductiveautomation.ignition.client.util.JxBrowserUtil.lambda$getOrCreateEngine$2(JxBrowserUtil.java:352)
at com.inductiveautomation.ignition.client.util.JxBrowserUtil.runResourceLockedAction(JxBrowserUtil.java:567)
at com.inductiveautomation.ignition.client.util.JxBrowserUtil.getOrCreateEngine(JxBrowserUtil.java:352)
at com.inductiveautomation.ignition.client.util.JxBrowserUtil.getOrCreateEngine(JxBrowserUtil.java:431)
at com.inductiveautomation.perspective.designer.DesignerHook.startup(DesignerHook.java:236)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$LoadedModule.startup(IgnitionDesigner.java:2004)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.startupModule(IgnitionDesigner.java:1200)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.loadProject(IgnitionDesigner.java:1003)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$StartupProjectDialogHandler.lambda$new$2(IgnitionDesigner.java:2048)
13:49:29.775 [Designer-Startup] INFO designer.main -- Starting module: Vision [+602988]
13:59:30.089 [Designer-Startup] ERROR designer.JXBrowserUtil -- Failed to start Browser Engine with options
chromiumSwitches:
diskCacheSize:
language:en-us
passwordStore:
userAgent:
userDataDir:C:\Users\borenerj\AppData\Local\Temp\JxBrowser-UserData-1f22f45b-5043-4110-a2b3-fbf7eaead145
at com.inductiveautomation.webbrowser.BrowserInstanceManager.startup(BrowserInstanceManager.java:36)
at com.inductiveautomation.factorypmi.application.FPMIApp.createApp(FPMIApp.java:335)
at com.inductiveautomation.factorypmi.designer.model.VisionDesignerImpl.createRoot(VisionDesignerImpl.java:711)
at com.inductiveautomation.factorypmi.designer.model.VisionDesignerImpl.startup(VisionDesignerImpl.java:371)
13:59:30.089 [Designer-Startup] ERROR WebBrowser -- BrowserEngine was not initialized. Web Browser Component can not start!
13:59:31.452 [Designer-Startup] INFO designer.main -- Starting module: SFC [+1204665]
13:59:31.924 [Designer-Startup] INFO designer.main -- Starting module: Event Streams [+1205137]
13:59:31.985 [Designer-Startup] INFO designer.main -- Starting module: OpcCom [+1205198]
13:59:31.985 [Designer-Startup] INFO designer.main -- Starting module: Reporting [+1205198]
13:59:32.039 [Designer-Startup] INFO reporting.Designer -- Starting up Reporting Module. Mode: Activated
13:59:32.234 [Designer-Startup] INFO designer.main -- Starting module: Symbol Factory [+1205447]
13:59:32.237 [Designer-Startup] INFO designer.main -- Starting module: Alarm Notification [+1205450]
13:59:32.340 [Designer-Startup] INFO designer.main -- Starting module: OPC-UA [+1205553]
13:59:32.340 [Designer-Startup] INFO designer.main -- Starting module: Enterprise Administration [+1205553]
13:59:32.358 [Designer-Startup] INFO designer.main -- Starting module: Legacy DNP3 Driver [+1205571]
13:59:32.358 [Designer-Startup] INFO designer.main -- Starting module: Historian Core [+1205571]
13:59:32.359 [Designer-Startup] INFO designer.main -- Starting module: SQL Bridge [+1205572]
13:59:32.504 [Designer-Startup] INFO designer.main -- Starting module: Kafka Connector [+1205717]
13:59:32.505 [Designer-Startup] INFO designer.main -- Starting module: WebDev [+1205718]
13:59:32.518 [Designer-Startup] INFO designer.main -- Initializing Scripting... [+1205731]
13:59:32.575 [Designer-Startup] INFO designer.main -- Initializing UI... [+1205788]
Clear your cache and download designer from designer launcher again, or call (official) support if this is urgent.
This is the most common reason, particularly on Windows. (Because IT must be insanely restrictive to secure it.)
I just ran into this issue and found a number of chromium background processes in task manager. I closed my designer session and hit end task on all chromium processes. One of them threw an error before ending.
I opened the designer launcher again, tried to open the project, and it just worked. I assume something weird got held up. Probably shouldn't have left everything open over the weekend...
