Designer Launcher could not load the project
Need help! I could not open the ignition project with Designer Launcher, it always stop at 83%, restarted the laptop and it is the same. show "Download attempt #2 for file security-8.1.43.jar failed." in Launch_error.
Ignition: Version: 8.1.43 (b2024082010)
Designer Launcher Version: 1.1.43
My colleague can open the project.
Can you attach a copy of your designerlauncher.log file from ~/.ignition/clientlauncher-data?
designerlauncher.log (17.6 KB)
Thanks!
Ok, can you copy/paste the command from that log and into a terminal and then run it and copy the output back to this thread?
C:\Users\Burensaiyin\AppData\Roaming\Inductive Automation\Designer Launcher\jre\bin\java.exe -classpath C:\Users\Burensaiyin\.ignition\cache\resources\platform\launchclient.jar\000000004B7512FD\launchclient.jar -Djavaws.sr.gateway.addr.0=http://192.170.8.10:8088 -Djavaws.sr.launchts=1734988736118 -Djavaws.sr.main=com.inductiveautomation.ignition.designer.DesignerStartupHook -Djavaws.sr.platform.edition= -Djavaws.sr.platform.plugins= -Xms64M -Xmx4096M -Djavaws.sr.memory.init=64M -Djavaws.sr.memory.max=4096M --add-opens=java.desktop/java.awt=ALL-UNNAMED --add-opens=java.desktop/java.awt.event=ALL-UNNAMED --add-opens=java.desktop/javax.swing=ALL-UNNAMED --add-opens=java.desktop/javax.swing.tree=ALL-UNNAMED --add-opens=java.desktop/javax.swing.plaf=ALL-UNNAMED --add-opens=java.desktop/javax.swing.plaf.basic=ALL-UNNAMED --add-opens=java.desktop/javax.swing.plaf.synth=ALL-UNNAMED --add-opens=java.base/java.lang=ALL-UNNAMED --add-opens=java.base/java.util=ALL-UNNAMED --add-exports=java.desktop/com.apple.eawt=ALL-UNNAMED --add-exports=java.desktop/com.sun.awt=ALL-UNNAMED --add-exports=java.desktop/com.sun.java.swing.plaf.windows=ALL-UNNAMED --add-exports=java.desktop/sun.awt=ALL-UNNAMED --add-exports=java.desktop/sun.awt.image=ALL-UNNAMED --add-exports=java.desktop/sun.awt.shell=ALL-UNNAMED --add-exports=java.desktop/sun.awt.windows=ALL-UNNAMED --add-exports=java.desktop/sun.swing=ALL-UNNAMED --add-exports=java.desktop/sun.swing.plaf.synth=ALL-UNNAMED --add-exports=java.desktop/sun.swing.table=ALL-UNNAMED --add-exports=java.desktop/sun.print=ALL-UNNAMED --add-exports=java.base/sun.security.action=ALL-UNNAMED -Dsun.java2d.d3d=false -Dsun.java2d.noddraw=false -Djavaws.sr.screen=0 -Djavaws.sr.scope=D com.inductiveautomation.ignition.client.launch.BootstrapSwing
C:\Users\Burensaiyin>C:\Users\Burensaiyin\AppData\Roaming"Inductive Automation""Designer Launcher1"\jre\bin\java.exe -classpath C:\Users\Burensaiyin.ignition\cache\resources\platform\launchclient.jar\000000004B7512FD\launchclient.jar -Djavaws.sr.gateway.addr.0=http://192.170.8.10:8088 -Djavaws.sr.launchts=1734988736118 -Djavaws.sr.main=com.inductiveautomation.ignition.designer.DesignerStartupHook -Djavaws.sr.platform.edition= -Djavaws.sr.platform.plugins= -Xms64M -Xmx4096M -Djavaws.sr.memory.init=64M -Djavaws.sr.memory.max=4096M --add-opens=java.desktop/java.awt=ALL-UNNAMED --add-opens=java.desktop/java.awt.event=ALL-UNNAMED --add-opens=java.desktop/javax.swing=ALL-UNNAMED --add-opens=java.desktop/javax.swing.tree=ALL-UNNAMED --add-opens=java.desktop/javax.swing.plaf=ALL-UNNAMED --add-opens=java.desktop/javax.swing.plaf.basic=ALL-UNNAMED --add-opens=java.desktop/javax.swing.plaf.synth=ALL-UNNAMED --add-opens=java.base/java.lang=ALL-UNNAMED --add-opens=java.base/java.util=ALL-UNNAMED --add-exports=java.desktop/com.apple.eawt=ALL-UNNAMED --add-exports=java.desktop/com.sun.awt=ALL-UNNAMED --add-exports=java.desktop/com.sun.java.swing.plaf.windows=ALL-UNNAMED --add-exports=java.desktop/sun.awt=ALL-UNNAMED --add-exports=java.desktop/sun.awt.image=ALL-UNNAMED --add-exports=java.desktop/sun.awt.shell=ALL-UNNAMED --add-exports=java.desktop/sun.awt.windows=ALL-UNNAMED --add-exports=java.desktop/sun.swing=ALL-UNNAMED --add-exports=java.desktop/sun.swing.plaf.synth=ALL-UNNAMED --add-exports=java.desktop/sun.swing.table=ALL-UNNAMED --add-exports=java.desktop/sun.print=ALL-UNNAMED --add-exports=java.base/sun.security.action=ALL-UNNAMED -Dsun.java2d.d3d=false -Dsun.java2d.noddraw=false -Djavaws.sr.screen=0 -Djavaws.sr.scope=D com.inductiveautomation.ignition.client.launch.BootstrapSwing
Error: Could not find or load main class Automation"Designer Launcher1\jre\bin\java.exe
Caused by: java.lang.ClassNotFoundException: Automation"Designer Launcher1\jre\bin\java.exe
Thank you very much for your help!
I have the java.exe in the folder.
Seems to have been a major copy paste error in whatever you tried.
Claiming id in C:\Users\Burensaiyin.ignition\cache\gw192.170.8.10_8088...
... obtaining lock
... lock obtained.
... claimed id 0
Calculated necessary downloads:
<?xml version="1.0" encoding="UTF-8"?> Downloading "http://192.170.8.10:8088/system/jar/m/security-8.1.43.jar" (timeout=60000)... Connect successful. Starting download of 18755 bytes Only read 15550 bytes in 60022ms! Download attempt #0 for file security-8.1.43.jar failed. java.net.SocketTimeoutException: Read timed out at java.base/sun.nio.ch.NioSocketImpl.timedRead(NioSocketImpl.java:288) at java.base/sun.nio.ch.NioSocketImpl.implRead(NioSocketImpl.java:314) at java.base/sun.nio.ch.NioSocketImpl.read(NioSocketImpl.java:355) at java.base/sun.nio.ch.NioSocketImpl$1.read(NioSocketImpl.java:808) at java.base/java.net.Socket$SocketInputStream.read(Socket.java:976) at java.base/java.io.BufferedInputStream.fill(BufferedInputStream.java:244) at java.base/java.io.BufferedInputStream.read1(BufferedInputStream.java:284) at java.base/java.io.BufferedInputStream.read(BufferedInputStream.java:343) at java.base/sun.net.www.MeteredStream.read(MeteredStream.java:141) at java.base/java.io.FilterInputStream.read(FilterInputStream.java:132) at java.base/sun.net.www.protocol.http.HttpURLConnection$HttpInputStream.read(HttpURLConnection.java:3733) at java.base/java.io.FilterInputStream.read(FilterInputStream.java:132) at com.inductiveautomation.ignition.client.launch.steps.StepInputStreamWrapper.read(StepInputStreamWrapper.java:46) at java.base/java.io.FilterInputStream.read(FilterInputStream.java:132) at com.inductiveautomation.ignition.client.launch.util.CRC32InputStream.read(CRC32InputStream.java:35) at java.base/java.io.FilterInputStream.read(FilterInputStream.java:106) at com.inductiveautomation.ignition.client.launch.steps.DownloadJarsStep.downloadJar(DownloadJarsStep.java:172) at com.inductiveautomation.ignition.client.launch.steps.DownloadJarsStep$DownloadJarsAction.run(DownloadJarsStep.java:77) at com.inductiveautomation.ignition.client.launch.steps.DownloadJarsStep$DownloadJarsAction.run(DownloadJarsStep.java:58) at com.inductiveautomation.ignition.client.launch.steps.AbstractLaunchStep.runLockedAction(AbstractLaunchStep.java:95) at com.inductiveautomation.ignition.client.launch.steps.BaseStep.runLockedAction(BaseStep.java:24) at com.inductiveautomation.ignition.client.launch.steps.DownloadJarsStep.run(DownloadJarsStep.java:55) at com.inductiveautomation.ignition.client.launch.AbstractStepRunner.run(AbstractStepRunner.java:33) at java.base/java.lang.Thread.run(Thread.java:840) Downloading "http://192.170.8.10:8088/system/jar/m/security-8.1.43.jar" (timeout=60000)... Connect successful. Starting download of 18755 bytes Only read 15550 bytes in 60017ms! Download attempt #1 for file security-8.1.43.jar failed. java.net.SocketTimeoutException: Read timed out at java.base/sun.nio.ch.NioSocketImpl.timedRead(NioSocketImpl.java:288) at java.base/sun.nio.ch.NioSocketImpl.implRead(NioSocketImpl.java:314) at java.base/sun.nio.ch.NioSocketImpl.read(NioSocketImpl.java:355) at java.base/sun.nio.ch.NioSocketImpl$1.read(NioSocketImpl.java:808) at java.base/java.net.Socket$SocketInputStream.read(Socket.java:976) at java.base/java.io.BufferedInputStream.fill(BufferedInputStream.java:244) at java.base/java.io.BufferedInputStream.read1(BufferedInputStream.java:284) at java.base/java.io.BufferedInputStream.read(BufferedInputStream.java:343) at java.base/sun.net.www.MeteredStream.read(MeteredStream.java:141) at java.base/java.io.FilterInputStream.read(FilterInputStream.java:132) at java.base/sun.net.www.protocol.http.HttpURLConnection$HttpInputStream.read(HttpURLConnection.java:3733) at java.base/java.io.FilterInputStream.read(FilterInputStream.java:132) at com.inductiveautomation.ignition.client.launch.steps.StepInputStreamWrapper.read(StepInputStreamWrapper.java:46) at java.base/java.io.FilterInputStream.read(FilterInputStream.java:132) at com.inductiveautomation.ignition.client.launch.util.CRC32InputStream.read(CRC32InputStream.java:35) at java.base/java.io.FilterInputStream.read(FilterInputStream.java:106) at com.inductiveautomation.ignition.client.launch.steps.DownloadJarsStep.downloadJar(DownloadJarsStep.java:172) at com.inductiveautomation.ignition.client.launch.steps.DownloadJarsStep$DownloadJarsAction.run(DownloadJarsStep.java:77) at com.inductiveautomation.ignition.client.launch.steps.DownloadJarsStep$DownloadJarsAction.run(DownloadJarsStep.java:58) at com.inductiveautomation.ignition.client.launch.steps.AbstractLaunchStep.runLockedAction(AbstractLaunchStep.java:95) at com.inductiveautomation.ignition.client.launch.steps.BaseStep.runLockedAction(BaseStep.java:24) at com.inductiveautomation.ignition.client.launch.steps.DownloadJarsStep.run(DownloadJarsStep.java:55) at com.inductiveautomation.ignition.client.launch.AbstractStepRunner.run(AbstractStepRunner.java:33) at java.base/java.lang.Thread.run(Thread.java:840) Downloading "http://192.170.8.10:8088/system/jar/m/security-8.1.43.jar" (timeout=60000)... Connect successful. Starting download of 18755 bytes Only read 15550 bytes in 60005ms! Download attempt #2 for file security-8.1.43.jar failed. java.net.SocketTimeoutException: Read timed out at java.base/sun.nio.ch.NioSocketImpl.timedRead(NioSocketImpl.java:288) at java.base/sun.nio.ch.NioSocketImpl.implRead(NioSocketImpl.java:314) at java.base/sun.nio.ch.NioSocketImpl.read(NioSocketImpl.java:355) at java.base/sun.nio.ch.NioSocketImpl$1.read(NioSocketImpl.java:808) at java.base/java.net.Socket$SocketInputStream.read(Socket.java:976) at java.base/java.io.BufferedInputStream.fill(BufferedInputStream.java:244) at java.base/java.io.BufferedInputStream.read1(BufferedInputStream.java:284) at java.base/java.io.BufferedInputStream.read(BufferedInputStream.java:343) at java.base/sun.net.www.MeteredStream.read(MeteredStream.java:141) at java.base/java.io.FilterInputStream.read(FilterInputStream.java:132) at java.base/sun.net.www.protocol.http.HttpURLConnection$HttpInputStream.read(HttpURLConnection.java:3733) at java.base/java.io.FilterInputStream.read(FilterInputStream.java:132) at com.inductiveautomation.ignition.client.launch.steps.StepInputStreamWrapper.read(StepInputStreamWrapper.java:46) at java.base/java.io.FilterInputStream.read(FilterInputStream.java:132) at com.inductiveautomation.ignition.client.launch.util.CRC32InputStream.read(CRC32InputStream.java:35) at java.base/java.io.FilterInputStream.read(FilterInputStream.java:106) at com.inductiveautomation.ignition.client.launch.steps.DownloadJarsStep.downloadJar(DownloadJarsStep.java:172) at com.inductiveautomation.ignition.client.launch.steps.DownloadJarsStep$DownloadJarsAction.run(DownloadJarsStep.java:77) at com.inductiveautomation.ignition.client.launch.steps.DownloadJarsStep$DownloadJarsAction.run(DownloadJarsStep.java:58) at com.inductiveautomation.ignition.client.launch.steps.AbstractLaunchStep.runLockedAction(AbstractLaunchStep.java:95) at com.inductiveautomation.ignition.client.launch.steps.BaseStep.runLockedAction(BaseStep.java:24) at com.inductiveautomation.ignition.client.launch.steps.DownloadJarsStep.run(DownloadJarsStep.java:55) at com.inductiveautomation.ignition.client.launch.AbstractStepRunner.run(AbstractStepRunner.java:33) at java.base/java.lang.Thread.run(Thread.java:840) java.net.SocketTimeoutException: Read timed out at java.base/sun.nio.ch.NioSocketImpl.timedRead(NioSocketImpl.java:288) at java.base/sun.nio.ch.NioSocketImpl.implRead(NioSocketImpl.java:314) at java.base/sun.nio.ch.NioSocketImpl.read(NioSocketImpl.java:355) at java.base/sun.nio.ch.NioSocketImpl$1.read(NioSocketImpl.java:808) at java.base/java.net.Socket$SocketInputStream.read(Socket.java:976) at java.base/java.io.BufferedInputStream.fill(BufferedInputStream.java:244) at java.base/java.io.BufferedInputStream.read1(BufferedInputStream.java:284) at java.base/java.io.BufferedInputStream.read(BufferedInputStream.java:343) at java.base/sun.net.www.MeteredStream.read(MeteredStream.java:141) at java.base/java.io.FilterInputStream.read(FilterInputStream.java:132) at java.base/sun.net.www.protocol.http.HttpURLConnection$HttpInputStream.read(HttpURLConnection.java:3733) at java.base/java.io.FilterInputStream.read(FilterInputStream.java:132) at com.inductiveautomation.ignition.client.launch.steps.StepInputStreamWrapper.read(StepInputStreamWrapper.java:46) at java.base/java.io.FilterInputStream.read(FilterInputStream.java:132) at com.inductiveautomation.ignition.client.launch.util.CRC32InputStream.read(CRC32InputStream.java:35) at java.base/java.io.FilterInputStream.read(FilterInputStream.java:106) at com.inductiveautomation.ignition.client.launch.steps.DownloadJarsStep.downloadJar(DownloadJarsStep.java:172) at com.inductiveautomation.ignition.client.launch.steps.DownloadJarsStep$DownloadJarsAction.run(DownloadJarsStep.java:77) at com.inductiveautomation.ignition.client.launch.steps.DownloadJarsStep$DownloadJarsAction.run(DownloadJarsStep.java:58) at com.inductiveautomation.ignition.client.launch.steps.AbstractLaunchStep.runLockedAction(AbstractLaunchStep.java:95) at com.inductiveautomation.ignition.client.launch.steps.BaseStep.runLockedAction(BaseStep.java:24) at com.inductiveautomation.ignition.client.launch.steps.DownloadJarsStep.run(DownloadJarsStep.java:55) at com.inductiveautomation.ignition.client.launch.AbstractStepRunner.run(AbstractStepRunner.java:33) at java.base/java.lang.Thread.run(Thread.java:840)
9 times out of 10 when somebody encounters an error like this it's because of a firewall, VPN configuration, packet filtering, network appliance, etc... that is inspecting the JAR files and deciding it doesn't like the contents.
You'll probably need some assistance from your IT department.
