Hi Specialists,
First of all, sorry if there is such topic already, but I did not manage to find it. My problem is that when I am trying to start the “Designer Launcher “, it does not come up. It does not appear in “Task Manager” at all. I power cycled my computer, I reinstalled the Java 64bit, I reinstalled and the “Designer Launcher” as well. Unfortunately, it still does not launch. The gateway is working and when I write http://localhost:8088/ it appears ant it is green.
If somebody have seen such thing before please help because I have a project assigned and I even can not start doing it.
I found that in Designer log file:
INFO [DesignerLauncher ] [2020/12/13 12:40:07]: Set initial logging level to INFO
INFO [DesignerLauncher ] [2020/12/13 12:40:07]: Updating logging level to INFO
ERROR [RuntimeException ] [2020/12/13 12:40:07]: Uncaught exception in thread: main
java.lang.RuntimeException: Exception in Application init method
- at com.sun.javafx.application.LauncherImpl.launchApplication1(LauncherImpl.java:895)*
- at com.sun.javafx.application.LauncherImpl.lambda$launchApplication$2(LauncherImpl.java:195)*
- at java.base/java.lang.Thread.run(Thread.java:834)*
Caused by: java.lang.NullPointerException - at com.inductiveautomation.ignition.launcher.common.ui.base.BaseLauncherApplication.lambda$init$0(BaseLauncherApplication.java:134)*
- at java.base/java.util.ArrayList.forEach(ArrayList.java:1540)*
- at com.inductiveautomation.ignition.launcher.common.ui.base.BaseLauncherApplication.init(BaseLauncherApplication.java:132)*
- at com.inductiveautomation.ignition.launcher.designer.ui.DesignerLauncherApplication.init(DesignerLauncherApplication.java:120)*
- at com.sun.javafx.application.LauncherImpl.launchApplication1(LauncherImpl.java:824)*
- … 2 more*
