Hello, dear specialists
I am using ignition maker Edition version 8.1.13. The URL is displayed correctly when I open Designer Launcher and select Add Designer. However, when I select open designer to run the program it just downloads some files for a cash then nothing happens. So, I cannot use designer launcher.
To solve this problem, I have done the following:
- I uninstalled and reinstalled designer launcher and ignition maker several times
- I deleted the cash memory
- I have used Java 10.0.2 and Java8
But also, the problem is not solved. Thank you for helping me to solve this problem.
