Designer launcher
please help me regarding this matter, when i clicked ok it will open a page where to download the oracle java, and tried to download and install it and still it shows this prompt shows
what should i do to ?
thanks in advance
It looks like your “Designer Launcher” Shortcut is pointing to an old java file.
Your java probably did an “Update” and your shortcut is pointing to the old version.
Unless you moved the location of the exe after you ran the installer you should not be getting this as you are using a bundled JRE included in the installer. There should be a jre/ folder in the same directory as the exe.
yes there is jre/ folder exe file
i tried to reinstall the designer launcher and it works hehe
