I'm currently having an issue where when someone opens the designer he sees "listing all available user roles". Almost like the designer can't contact the identity providers (AD) but the vision client don't have any issues, every normal users are connected without any problems it only happens when the he opens the designer
Here's the type of errors we're facing
GatewayException: Read timed out caused by SocketTimeoutException: Read timed out
Ignition v8.1.52
Java: Azul Systems, Inc. 17.0.17
Error 2 :
GatewayException: The connection to the gateway is not available.
Ignition v8.1.52
Error 3 :
Ignition v8.1.52
Error 4 :
Ignition v8.1.52
Error 5 :
Ignition v8.1.52
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Read timed out
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:360)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:556)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:292)
at com.inductiveautomation.ignition.designer.gateway.PriviledgedDesignerTask$GatewayMessageTask.execute(PriviledgedDesignerTask.java:440)
at com.inductiveautomation.ignition.designer.gateway.PriviledgedDesignerTask$TaskThread.run(PriviledgedDesignerTask.java:328)
Caused by: java.net.SocketTimeoutException: Read timed out
at java.base/sun.nio.ch.NioSocketImpl.timedRead(Unknown Source)
at java.base/sun.nio.ch.NioSocketImpl.implRead(Unknown Source)
at java.base/sun.nio.ch.NioSocketImpl.read(Unknown Source)
at java.base/sun.nio.ch.NioSocketImpl$1.read(Unknown Source)
at java.base/java.net.Socket$SocketInputStream.read(Unknown Source)
at java.base/java.io.BufferedInputStream.fill(Unknown Source)
at java.base/java.io.BufferedInputStream.read1(Unknown Source)
at java.base/java.io.BufferedInputStream.read(Unknown Source)
at java.base/sun.net.www.http.HttpClient.parseHTTPHeader(Unknown Source)
at java.base/sun.net.www.http.HttpClient.parseHTTP(Unknown Source)
at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream0(Unknown Source)
at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at java.base/java.net.HttpURLConnection.getResponseCode(Unknown Source)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.getResponse(GatewayInterface.java:450)
... 4 more
Ignition v8.1.52
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: The connection to the gateway is not available.
at com.inductiveautomation.ignition.designer.gateway.PriviledgedDesignerTask$GatewayMessageTask.canRun(PriviledgedDesignerTask.java:450)
at com.inductiveautomation.ignition.designer.gateway.PriviledgedDesignerTask.run(PriviledgedDesignerTask.java:161)
at com.inductiveautomation.ignition.designer.gateway.PriviledgedDesignerTask.runTask(PriviledgedDesignerTask.java:146)
at com.inductiveautomation.ignition.designer.gateway.DTGatewayInterface.getRoles(DTGatewayInterface.java:426)
at com.inductiveautomation.factorypmi.designer.model.VisionDesignerImpl.getRoles(VisionDesignerImpl.java:1943)
at com.inductiveautomation.factorypmi.designer.eventhandling.ActionQualPanel$SecurityPanel.initComponents(ActionQualPanel.java:271)
at com.inductiveautomation.factorypmi.designer.eventhandling.ActionQualPanel$SecurityPanel.(ActionQualPanel.java:261)
at com.inductiveautomation.factorypmi.designer.eventhandling.ActionQualPanel.(ActionQualPanel.java:56)
at com.inductiveautomation.factorypmi.designer.eventhandling.TagSetBuilder.initComponents(TagSetBuilder.java:99)
at com.inductiveautomation.factorypmi.designer.eventhandling.TagSetBuilder.(TagSetBuilder.java:57)
at com.inductiveautomation.factorypmi.designer.eventhandling.ActionConfigPanel.(ActionConfigPanel.java:63)
at com.inductiveautomation.factorypmi.designer.eventhandling.ComponentScriptEditor.initComponents(ComponentScriptEditor.java:224)
at com.inductiveautomation.factorypmi.designer.eventhandling.ComponentScriptEditor.(ComponentScriptEditor.java:110)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace$Handler.getScriptEditor(WindowWorkspace.java:3089)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace$Handler.configureEventHandlers(WindowWorkspace.java:3103)
at com.inductiveautomation.vision.api.designer.beans.OpenEventScriptingHandler.onDoubleClick(OpenEventScriptingHandler.java:25)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.handleDoubleClick(WindowWorkspace.java:976)
at com.inductiveautomation.ignition.designer.designable.tools.SelectionTool.onDoubleClick(SelectionTool.java:553)
at com.inductiveautomation.ignition.designer.designable.DesignPanel$ToolMouseListener.onClick(DesignPanel.java:975)
at com.inductiveautomation.ignition.client.util.gui.CommonMouseAdapter.mouseReleased(CommonMouseAdapter.java:72)
at java.desktop/java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.base/java.security.AccessController.doPrivileged(Unknown Source)
at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
Ignition v8.1.52
At this point i don't even know where i should look at to be honest. Hope you can help me with that. Thanks in advance
