Cannot get designer to launch when gateway is setup to use non-standard SSL port
port 8042 - Ignition Edge - Designer won’t start - socket timeout error
port 8043 - Ignition Full - Designer works fine
port 8044 - Ignition Full - Designer won’t start - socket timeout error
All on Ubuntu 16.04 LTS
All 7.9.3
Can navigate to gateway via SSL on all.
Bug, configuration, or ID-10-T issue???
Once you configure SSL on 8044 do you download a new JNLP file before you try to launch?
Yes, I have downloaded many JNLPs from the gateway since changing the ssl port…
I have also tried the client launcher and get the following in its log:
ERROR [GatewayConfigPanel ] [05:14:14,403]: PingWorker: Caught Exception:
java.net.SocketException: Unexpected end of file from server
at sun.net.www.http.HttpClient.parseHTTPHeader(Unknown Source)
at sun.net.www.http.HttpClient.parseHTTP(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source)
at java.net.HttpURLConnection.getResponseCode(Unknown Source)
at com.inductiveautomation.ignition.client.nativelaunch.util.GatewayCommUtil.getGatewayConnection(GatewayCommUtil.java:96)
at com.inductiveautomation.ignition.client.nativelaunch.util.GatewayCommUtil.getGatewayRawResponse(GatewayCommUtil.java:126)
at com.inductiveautomation.ignition.client.nativelaunch.util.GatewayCommUtil.pingGateway(GatewayCommUtil.java:152)
at com.inductiveautomation.ignition.client.nativelaunch.ui.GatewayConfigPanel$PingWorker.doInBackground(GatewayConfigPanel.java:1624)
at com.inductiveautomation.ignition.client.nativelaunch.ui.GatewayConfigPanel$PingWorker.doInBackground(GatewayConfigPanel.java:1608)
at javax.swing.SwingWorker$1.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at javax.swing.SwingWorker.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
ERROR [GatewayConfigPanel ] [05:14:14,408]: Gateway did not return a status of RUNNING: Unexpected end of file from server
A bit more information…
All works fine when I try to run the designer from a computer on the same network as the Ignition server. The failures only occur when the connection is going through a router. I have three Ignition servers and am using 3 different SSL ports. The server using 8043 works fine, the other two (8042 and 8044) fail.
Ignition uses both SSL and non-SSL ports when in SSL mode. You’ll have to change the non-ssl port for the two other servers and make sure they pinhole through your router, too.
