Designer script console executes code while perspective bindings fail on the exact same code
I have a server that I query regularly that holds our ERP software. I get information from the ERP server via SQL something like below:
shared.oodbapi.fetchDataSQL("SELECT TOP 5 clockNumber FROM Employees")
Which I can then bind to a component to display the results.
The weird part is that when I add a binding like the above query to a component it fails saying I can't POST. If I execute the same statement in the designer script console it works and no error occurs; it works as expected.
The ERP server requires an HTTPS connection so I'm not sure why I can POST in the console but not in the designer.
This is the error that I get from perspective:
Description
File "<transform>", line 2, in transform File "<module:shared.oodbapi>",
line 48, in fetchDataSQL at com.inductiveautomation.ignition.common.script.builtin.http.JythonHttpClient.send(JythonHttpClient.java:94) at
com.inductiveautomation.ignition.common.script.builtin.http.JythonHttpClient.post(JythonHttpClient.java:309) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at
java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at
java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at
java.base/java.lang.reflect.Method.invoke(Unknown Source) java.io.IOException: java.io.IOException:
Unable to POST https://odyssey.lethiron.com/odyssey/api/FetchData/SQL
the function definition
def fetchDataSQL(query, limit=1800):
    """fetch data from Odyssey using SQL
    params:
        query: str - SQL query to execute
        limit: int - number of records to return
    returns:
        data: list - list of dicts with keys being each field in the query
    client = system.net.httpClient()
    url = "{}FetchData/SQL".format(BASE_URL)
    company = system.tag.readBlocking(COMPANY_TAG)[0].value
    params = {
        "SQLQuery": query,
        "Page": 1,
        "BatchSize": limit,
        "CompanyID": company,
        "APIKey": API_KEY,
    response = client.post(url, data=params) # its complaining here
    if response.json["Success"]:
        return list(response.json["DataSetOut"]["tTemptable"])
    raise BadOdysseyQueryError(response.json["ErrorMessage"])
Any idea why this is happening? Thanks in advance.
Scripts executing in Perspective (even the Perspective session open in your designer) are actually running on the gateway. The script console is running code on your local computer.
That's the difference.
There's probably further details on the exception somewhere in the gateway logs; Unable to POST is not particularly helpful. However, one of more common issues is bad DNS on the Gateway, due to overzealous/incompetent/overworked/etc IT teams.
Ah ok that would explain why my development server doesn't have the same issue
Good old restart fixed the issue. It seems the power was pulled abruptly last night and we all know how much computers like a sudden loss of power. Everything reset after the restart of the server. Thanks for the quick reply @paul-griffith!
