Hello everyone,
I am seeing a very strange behavior and I don't know where to look to solve it, it turns out that I have (image 1) the Designer with the correct configuration and operational.
DESIGNER:
control Value:
IndicatorValue:
but in the vision I see that it is not working, it is always in stopped when it has to be in runnig as shown in the designer
VISION:
maybe there is something I have missed, but do you know how to fix it?
The sp_on custom property is an integer. How does this get set?
yes and is indexed by an indirecttag
Make sure this tag is evaluating correctly in the client, since this is what sets your button.
yes, in fact the value I get is 1 and the multistate button state determines that 1 is running and 0 is stopped
Tip: {Root Container.sp_on} will always return a true or false so you can reduce your expression to,
if({Root Container.sp_on}, 1, 0)
Sorry, I can't see what's wrong with your binding.
