Just upgraded to 8.1.43 and having a heck of a time with SSL when using HTTPClient() in designer script console.
We had all the supplemental certs installed on both the Designer Launcher and on the gateway. I have cleared all the local cache on my machine and re-installed the designer launcher, but no matter what I do it seems to download a JRE from the server without my custom internal Certs.
The launcher works fine as its using the system cert store. The GW is fine as well. I tried setting the custom.jre.path setting in the launcher config but then the login button on the designer just does nothing.
Is something mis-configured? How can I get the designer to do what it used to and just use the jre bundled with the launcher and respect the certificates in clientlauncher-data folder.
