Designer Text Size Issue
I am having the strangest issue with the designer. This is an older gateway 8.1.28
The text is large for no reason. It was not like this earlier today then I got back on and pulled up the designer and it’s huge. I have restarted everything and it is staying like this.
Any Ideas?
Windows display scaling change? Or was the Windows font size changed?
It’s only the designer…everything else is exactly the same.
Did you launch it with the same designer config? I think there's a high dpi option that affects font sizing, but you have to add it manually to the config file…
Failing that, try deleting the cached files for your designer
I used the same one and cleared the cache (that is always my first idea with weirdo designer issues)
I tried a different server just now and it has the same issue, but again only for the designer. I tried different gateways on both as well and same result.
EDIT: It must be a weird windows thing…I just uninstalled and reinstalled the designer launcher and it is still happening.
Restarted the OS?
I will have to have the customer’s IT handle that.
I found a third sever I can use that doesn’t have that issue. I suppose I will have them restart and return here to mark it as a standard windows woe and consider it resolved.
