What happen to the designtime security tool that was available in FactoryPMI. I am trying to navigate in my designer and I don’t want to change the security on components back and forth.
Thank you,
Thank you,
We got rid of it because it caused people massive problems serializing components in their restricted state. We no longer suggest that you test your security settings in the Designer - you should test them in a running client. In fact, security settings don’t take effect anymore in the Designer’s preview mode. Use the manual publish system to separate a “Staging” client from a “Production” client.
ok, thanks i will give the staging a try.
