I deployed ignition as a client to a new computer (windows server 2005, Java 6b18). The desktop shortcut worked once and now fails everytime with the following error:
Could not load file/URL specifed: C:\Documents and settings\h2oops.KMCGCPR1\Application Data\Sun\Java\Deplyment\cache\6.0\25\4a46d059-712507f8
The exception info is below:
CouldNotLoadArgumentException[ Could not load file/URL specified: C:\Documents and Settings\h2oops.KMCGCPR1\Application Data\Sun\Java\Deployment\cache\6.0\25\4a46d059-712507f8]
at com.sun.javaws.Main.launchApp(Unknown Source)
at com.sun.javaws.Main.continueInSecureThread(Unknown Source)
at com.sun.javaws.Main$1.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
The wrapper exception is below:
java.io.FileNotFoundException: C:\Documents and Settings\h2oops.KMCGCPR1\Application Data\Sun\Java\Deployment\cache\6.0\25\4a46d059-712507f8 (The system cannot find the file specified)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.(Unknown Source)
at com.sun.javaws.jnl.LaunchDescFactory.buildDescriptor(Unknown Source)
Thoughts? Running the application by clicking on the .JNLP file downloaded from the gateway works fine… Its just the shortcut that has the error. The first time I ran the short cut I did encounter a scripting error which I resolved on the gateway so it should be fine now.
