Creating frame. extendedState=6, bounds=java.awt.Rectangle[x=0,y=0,width=1024,height=768]
INFO [Gateway-Thread-16] Starting up polling tag manager, polling rate: 250 ms
INFO [ReportingClientHook-Thread-16] Starting up Reporting Module. Mode: Activated
Initializing ReportMill (Build Date: May-27-05, Version 9.0, JVM 23.25-b01, User lisawas)
INFO [ClientPanel-AWT-EventQueue-2] Received project change notification: notificationMode=PUSH, updateMessage=ProjectUpdated(editCount=857, uuid=e6b7a67d-a414-481b-3bb4-8362b507de6a)
INFO [FPMIApp-AWT-EventQueue-2] Starting Up...
From initialization function:
Initialization has started in background thread.
From confirmWindowOpen function:
Opening Monitoring_Splash
INFO [UpdateProjectPane-ProjectUpdater] Downloading "http://172.28.33.236:80/main/system/project/C/P/856/e6b7a67d-a414-481b-3bb4-8362b507de6a/OEE_Andon_Debug"...
INFO [UpdateProjectPane-ProjectUpdater] Connect successful.
INFO [UpdateProjectPane-ProjectUpdater] Starting download of 710016 bytes
INFO [UpdateProjectPane-ProjectUpdater] Download successful
Writing project to cache file C:\Users\lisawas.ignition\cache\gw172.28.33.236_80_8043_main\C1\CPOEE_Andon_Debug.proj
Window opened successfully after 4095 cycles.
Window opened successfully after 0 cycles.
From updateSplashText function:
New line added: Login: lisawas
New line added: Building ID: 28
New line added: IDs of Monitored Areas: 2, 3, 4, 1
New line added: Sound configuration: 3
Client tag change detected:
Tag: [Client]ANDON/BuildingID
Value: 28
Quality: Good
Time: Tue Aug 06 11:33:06 MST 2013
Tag: [Client]ANDON/AreaNameSqlList
Value: 2, 3, 4, 1
Quality: Good
Value: 28
Quality: Good
Value: 2, 3, 4, 1
Quality: Good
Station Data has 59 row(s), 6 column(s).
Rotator Data has 59 row(s), 4 column(s).
