Determining SVG viewBox property dynamically
As part of my quest to make our sites entirely auto-deployable from a common stack of projects, and based on some help from an esteemed forum member, I now have a component in our UI library that can take a tagPath and auto-generate a diagram with SVGs and ViewCanvas solely from the tag provider.
But the one thing I can't figure out how to do is pre-determine the height and width for the ensemble of components based on the size of content within the SVG. What I want is essentially the dimensions found in a SVG component's viewBox custom property upon embedding a SVG. But I want to calculate the height and width based on the SVG content coming in from a binding.
Does anyone know how Ignition determines the viewBox prop upon embedding a SVG, and if that is exposable at runtime? Or another way for me to determine the dimensions of bound SVG elements?
This would empower me to make this a generic card component that can be called in any context solely with a tagPath parameter.
I thought the viewbox was defined in the SVG?
Oh yeah, it's right there in the opening xml tag when it's actually xml, e.g.. <svg width="1012" height="558" viewBox="0 0 1012 558" fill="none" xmlns="http://www.w3.org/2000/svg">
Unfortunately this gets lost when we process it into lists of dictionaries for bindability in Ignition and document-formatted storage in the tag provider. But now I know where Ignition gets it :smiley: and I can try to figure out a creative way to make it persist into the tag provider.
Instead of capturing just props.elements, capture the others too. When reading the doc tag, you get them all one layer deeper.
