DeveloperModuleLoadingServlet
For my module development, I am using a mixture of the Ignition Maven Plugin and the Gradle Module Plugin. I know there are tasks there to deploy to a Gateway running in "Development" mode. The issue that I am running into is that I have a "license" html file that is provided with my modules. When I try to upload to the DeveloperModuleLoadingServlet I have an error thrown
Cannot start up module "com.mycompany.namespace", it doesn't exist.
Around there, I see;
Moving module mymodulename to quarantine because license not yet accepted.
Is there a way to auto accept the license through this servlet?
@Kevin.Herron and @PerryAJ it looks like you wrote the original code for this so maybe you have an idea. Im not seeing anything obvious looking at ignition-maven-plugin/src/main/java/com/inductiveautomation/ignitionsdk/PostModuleMojo.java at 71f4d87649edf7f97e0e16fa373a41b1987680df · inductiveautomation/ignition-maven-plugin · GitHub or ignition-module-tools/gradle-module-plugin/src/main/kotlin/io/ia/sdk/gradle/modl/task/Deploy.kt at 4fd236ab99605f165c610000eae27b3d13e60f92 · inductiveautomation/ignition-module-tools · GitHub
Install it once manually, accept the certificate, then use the action to automatically update it as you make changes.
Is it safe to assume that they use the EULAS table to store the accepted license file? The CRC value in this table looks to be a normal crc-32 value of the license file. Im looking to preconfigure the environment more. My license file tends to not change too often.
Yeah, the IDB is the 'source of truth' for this stuff (in 8.1, there are some differences in 8.3).
You could:
  1. Start from a clean system, take a .gwbk
  2. Install your module manually and accept the cert, take a .gwbk
  3. Run sqldiff to compare the IDB files between the two.
