Device Simulator Setup with existing Rockwell/AB OPC-UA tags
Currently have a setup on Ignition 8.1 utilizing a Perspective project and OPC-UA connection to an Rockwell/AB ControlLogix PLC. Most of the tags in the tag browser are imported from the OPC Browser as OPC tags, as Rockwell/AB devices support tag browsing.
At times, the PLC may be unavailable for development and was wondering if there is a good way to import the tags into the simulator in CSV format, such as converting the exported JSON or XML OPC tags, or getting a CSV from the PLC designer program (Studio 5000)
You might find this approach useful (IIRC, the device simulator doesn't handle Rockwell's dot-separators well):
Does this deal with PLC/Ignition AOIs/UDTs well by chance?
If you use the V2 beta instead of the stable version:
Note that the purpose in this topic is to emulate a logix processor, not connect to a logix processor. Performed by different drivers within my module. Only the beta can connect to a logix processor.
Yep I'm looking to emulate. Thanks for the info!
