Hello!
As I understand both keys are to launch ruintime, but there’s a little difference. I have a project with some windows in different folders. When press F9 the project runs normally, but when I use F10 the runtime does not find the windows. Can anybody tell me why this happens? How can I fix the problem?
Regards!
Hi Sam,
From the documentation:
[i]Project Versioning
Each project can have two distinct versions at once: the Staging version and the Published version. By default, a new project is configured to be in Auto publish mode, which means that the two versions are always identical. However, if you change a project to be in Manual publish mode, then you can explicitly publish a project in the Designer.
Published vs Staging
The general idea between having a published version and a staging version is to allow you to save a project, and then test out the changes before “publishing” those changes to a production environment. Under normal conditions, Vision module clients run the published version of a project. However, by launching a client in a special mode (from the Designer or from the Config section of the Gateway), you can launch a client that runs the staging version of that project. This staging client will receive updates on every save, where the production clients receive updates only on publish. This lets you test out your changes to the project in an actual client, which is more realistic than the Designer’s preview mode.
Not all aspects that comprise a project use this system. It is primarily intended for systems such as the Vision module’s clients. Features that run persistently on the Gateway, such as SQLTags, the SQL Bridge’s Transaction Groups, and Gateway-side scripting always run the most recently saved changes (the Staging version). Since these features by definition must run in exactly one place, they cannot be effectively “tested out” by simultaneously running a staging version alongside a published version.[/i]
